Differences between Android and Android TV images
I've just received my Rock64 and I'm planning to use Kodi and other multimedia apps on it, while it's connected to my TV.
Should i be using the Android 7.1.2 or the Android TV 7.1.2 image? What's the difference between the two?
Thanks!
(02-12-2018, 02:21 PM)1n9i9c7om Wrote: Hi,
Thanks!
Android TV uses the LeanBack launcher (also used on Nvidia Shield) and apps designed for the TV interface; its a community build. The stock image comes with regular Playstore, etc.,
Thanks!
Thanks for the quick reply!
So besides the launcher and pre-installed apps it's basically the same?
Thanks!
Kernel is the same etc., its just the interface. The TV playstore is limited compared to regular playstore, but you can side-load any 'regular' android apps you want.
[edit]: the ATV community build also lacks RKMC.
Thanks!
Alright, thank you!  Smile
Hi guys, quick question:
Does the TV version use the same "touch" approach of the standard Android or is it designed to use a non-touch input?
Thanks!
(04-11-2018, 10:53 AM)Danielsan Wrote: Hi guys, quick question:
Thanks!
the Android TV version still has the "touch" capability.
(04-15-2018, 08:51 PM)tllim Wrote: the Android TV version still has the "touch" capability.
Thanks I saw.
Eventually the Android root version performs better and has more software available. I though Android TV was like a vanilla version of Android for devices different from smartphone but it is just a version to promote google (payment) services and it is not even rooted.
I will return to the Android root version, I almost got how handle with the touchscreen inputs without a touchscreen.
Thanks I saw.
Where is the android root version?
  Android Images (ROCK64) pineadmin 77 247,061 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,534 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,810 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,984 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,953 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,657 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,813 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,494 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,738 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 9,102 09-18-2020, 07:58 PM
Last Post: BowerR64
