opencv on rock64
I just receive my first rock64. I installed xenial mate, all works fine.
There is a possibility to install openvc on rock64?
if it is possible can you help me to find the right way?
Roberto
You usually install opencv by building from source like this
https://www.pyimagesearch.com/2016/10/24...ll-opencv/
See how far you can get with that tutorial, there might be some tweaks needed to do that on ARM64...
Thanks!
the problem that I found is here:
$ sudo apt-get install libjpeg8-dev libtiff5-dev libjasper-dev libpng12-dev
libjpeg8-dev - I replaced it with libjpeg16-turbo-dev
libtiff5-dev - this one is ok
libjasper-dev libpng12-dev . - that library are not installation candidate
can I replay them with other libraries
Check packages.ubuntu.com if there are newer version of those packages first via the search feature (make sure to check xenial/arm64 filters), if there are no packages in the repos, check for PPAs, if those don't exist you have to build the missing dependencies from source...
  MRAA Rock64 support jbize 2 5,415 07-09-2022, 04:40 AM
Last Post: igorp
  Rock64 with Debian netinst usb Bloris 6 14,612 12-03-2019, 12:37 PM
Last Post: madalin
  The differences between Rock64 and RockPro64 phamoanh 1 7,344 06-12-2019, 10:44 PM
Last Post: evilbunny
  Custom Kernel for ROCK64 mayst 2 7,818 01-07-2019, 08:04 AM
Last Post: mayst
  Any success working with OpenCV on the PineA64? Tonny91 0 3,761 10-16-2018, 09:16 PM
Last Post: Tonny91
Bug Rock64 Login lpninja 1 7,107 10-04-2018, 12:02 AM
  Rock64 suitable for headless TVHeadend install? elsmandino 3 10,025 06-26-2018, 11:37 AM
Last Post: Luke
  Will the Rock64 work as a mobile data storage device? Kennetht 1 5,107 03-29-2018, 10:07 AM
Last Post: xalius
  Laptop as a bridge for Rock64's internet connection dmitrymyadzelets 3 8,488 03-28-2018, 05:24 AM
Last Post: dmitrymyadzelets
  Rock64 OS eMMC boot ProfessionalDreamer 2 7,962 02-20-2018, 08:44 PM
Last Post: ProfessionalDreamer
