x11 vnc black screen
I'm reasonably sure it has nothing to do with the video driver since I would've remembered that.
What is your desktop environment (LXDE here w LightDM)? Could you maybe try a 'sudo apt-get install xscreensaver' (and disable the screen saver) to see if it makes a difference?
(01-19-2018, 02:59 PM)soichiro Wrote: At this point, I will just set aside my rock64 and wait for an emmc version of DietPI that for what I saw and tested, if the fastest distro out there for the rock64.
I just used etcher to flash DietPi_v156_Rock64-arm64-(Stretch).img to my emmc card plugged into the USB adaptor  and so far no problems.
(01-22-2018, 02:35 AM)dontpostalot Wrote: I'm reasonably sure it has nothing to do with the video driver since I would've remembered that.
Hello dontpostalot, I just reinstalled Ubuntu, removed MATE and installed LXDE with lightDM and xscreensaver (disabling screen saver) but still, same issue Sad
Is it possible that DietPI is not working with an EMMC 8GB? I am asking this because for some reason I am unable to boot the OS with my 8GB but today, I tried to use my 32GB EMMC and it worked at the first try....
  Screen blinking pRcCjl4 2 6,164 09-10-2022, 03:35 PM
Last Post: pRcCjl4
  Screen lock fail Bionic-lxde-rock64-0.7.8-1061-arm64 electrique 0 3,738 12-28-2018, 11:00 PM
Last Post: electrique
  Screen flickering when playing multiple videos with rkximagesink matwey 2 6,903 05-15-2018, 02:09 AM
Last Post: matwey
