No HDMI Display need help with correct uEnv.txt settings
I am trying Ayufan's latest minimal xenial image for pine64
https://github.com/ayufan-pine64/linux-build/releases
It is booting and I can ssh to the board.  All seems fine except I can't get the HDMI port to function.
It is connected to my standard monitor which supports 1080p
Here is the only defaults (comments) I changed.  I've fiddled some with these but nothing not even a hint of communication with my monitor (like a flicker).
I am assuming my issue is just getting these settings correct?  Are there maybe other things I must do to get HDMI working?
# To enable LCD or HDMI, if not changed it will use default (experimental) #disp_screen0=lcd or hdmi disp_screen0=hdmi disp_screen1=hdmi # disp_mode=screen0 or screen1 or dualhead or xinerama or clone or disabled disp_mode=screen0 # USB OTG port mode (experimental) # otg_mode=device or host or otg otg_mode=host # Configure contiguous memory allocation # This maybe required to be enlarged for 4K displays cma=384M # To change HDMI display mode: # hdmi_mode=480i # hdmi_mode=576i # hdmi_mode=480p # hdmi_mode=576p # hdmi_mode=720p50 # hdmi_mode=720p60 # hdmi_mode=1080i50 # hdmi_mode=1080i60 # hdmi_mode=1080p24 # hdmi_mode=1080p50 hdmi_mode=1080p60 # hdmi_mode=2160p30 # hdmi_mode=2160p25 # hdmi_mode=2160p24 # hdmi_mode=800x480p # hdmi_mode=1024x600p
if you are using a hdmi to dvi setup then getting the monitor functional will take some experimenting with settings and depending on your setup may not work. i would suggest trying the latest arch linux build for pine64. it comes with xfce desktop installed. it will help narrow what the problem may be if you test that build.
(01-11-2018, 03:13 AM)dkryder Wrote: if you are using a hdmi to dvi setup then getting the monitor functional will take some experimenting with settings and depending on your setup may not work. i would suggest trying the latest arch linux build for pine64. it comes with xfce desktop installed.  it will help narrow what the problem may be if you test that build.
not sure what you mean "hdmi to dvi setup".    There is no dvi port on my monitor just hdmi.    This is a minimal build of Ubuntu, no desktop and yet unable to get the terminal/cli on the monitor.   On the RPI getting these similar settings "right" in the "config" file in /boot is usually the fix.  I am assuming the same.
I can't imaging that ayufan would make these builds that don't support hdmi on a standard monitor.  I must be missing something here.
Further not really wanting to use arch.  I am very familiar with ubuntu as it my main dev distro for other work.
yes, but if you spend 30min to test if the arch linux build boots and displays then you have a probable solution to get other build running. but, suit yourself.
(01-11-2018, 11:09 AM)dkryder Wrote: yes, but if you spend 30min to test if the arch linux build boots and displays then you have a probable solution to get other build running. but, suit yourself.
Burned instead this longsleep image upon which ayufan makes new builds.  It worked fine, not need to try arch.
https://www.stdin.xyz/downloads/people/l...es/ubuntu/
Obviously it's something amiss in that latest image of Ayufan.
for those finding this thread I jumped back to Ayufan's lastest "stable" release instead of pre-release and that worked fine
https://github.com/ayufan-pine64/linux-b.../tag/0.6.2
for the record , perhaps if you have the time, ayufan has previously requested that issues with any builds be entered in the proper github repo so that he can track the problems with specific builds. thanks.
(01-11-2018, 12:58 PM)dkryder Wrote: for the record , perhaps if you have the time, ayufan has previously requested that issues with any builds be entered in the proper github repo so that he can track the problems with specific builds. thanks.
I had already done this when I realized it was issue with his pre-release.
https://github.com/ayufan-pine64/linux-build/issues/55
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 6,894 04-19-2019, 08:26 AM
Last Post: psychedup
  lcd touch screen and hdmi output moreaujacky 2 8,468 10-24-2018, 07:24 AM
Last Post: lisanke
  HDMI Compatability rahlquist 5 13,322 07-29-2017, 02:32 AM
Last Post: qwerty2002
  Ongoing HDMI limited compatability rahlquist 39 84,090 05-21-2017, 12:59 PM
Last Post: lbdroid
  No HDMI Output martinarcher 2 9,745 04-28-2017, 07:05 AM
Last Post: martinarcher
Rainbow Pine64 + waveshare display? iPhyse 4 11,847 10-12-2016, 04:43 PM
Last Post: hamzahbondok
  Switching from touchscreen to HDMI AUDIOTEK 10 21,128 08-11-2016, 07:41 PM
Last Post: MarkHaysHarris777
  4K HDMI video output medapeta 3 10,260 06-10-2016, 04:36 PM
Last Post: shinobi
Sad display problem florianl 5 12,016 04-29-2016, 08:53 AM
Last Post: Luke
  HDMI Issue... LeRoms77 4 11,769 04-19-2016, 02:11 AM
Last Post: LeRoms77
