Debian Jessie image for Pinebook
Any plans for Debian Jessie image?
Thank you for no answer at all.
(12-29-2017, 04:07 PM)amilino Wrote: Thank you for no answer at all.
Must have missed your original post. Here you go: https://github.com/ayufan-pine64/linux-b...118.img.xz
How to connect on wifi with minimal version of stretch? I am trying to install LXDE.
By the way, what us the best choise of Debian for Pinebook?
(12-30-2017, 02:26 AM)amilino Wrote: By the way, what us the best choise of Debian for Pinebook?
Depends for what. Stretch has worked fine for me.
Yes, but there is only minimal version without Desktop.
(12-31-2017, 03:22 AM)amilino Wrote: Yes, but there is only minimal version without Desktop.
IIRC there should be a script in /usr/local/sbin to install either i3 or mate. Otherwise, you can just install any desktop youd like you would normally on any computer ... for instance, XFCE
Edit: also Q4OS is also debian: https://forum.pine64.org/showthread.php?tid=4506
And how to connect on wifi from terminal?
To connect to wifi from terminal either set up the config in /etc/interfaces (check Debian/Ubuntu wiki) or install a network manager command line interface like 'nmtui' ...
  DietPi OS for Pinebook MichaIng 5 16,746 07-28-2026, 08:02 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 14,424 05-18-2026, 02:11 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 102,924 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,781 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,378 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 16,366 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,327 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,553 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,256 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,400 01-20-2021, 11:18 AM
