First Lakka image for Rock64!
#21
(11-22-2017, 03:57 PM)Ntemis Wrote:
(11-22-2017, 03:55 PM)Luke Wrote:
(11-22-2017, 03:53 PM)Ntemis Wrote: Hello, just jumped over to inform you guys that Lakka v2.1 final is out with Retroarch v1.6.9.
Let me know if anything comes up Smile
Enjoy!
Glad to see you in the forum :Smile Have a read of the thread please - my only complaint was that many common controllers were not recognised, otherwise great. I will check out the new image tomorrow.
Controller issues should be gone by now Smile
Hello. I'm trying to set a Bluetooth controller up, the controller works fine plugged into USB.
systemctl status Bluetooth shows it as running
Typed bluetoothctl, agent on, default-agent all worked good.
Once I got to power on I receive "No default controller available"
Cannot find any information about this besides pi and people say to update the Bluetooth with apt-get which I cannot do with Lakka.
Does Bluetooth in Lakka even work with Rock64??
Enjoy!
Rock64 doesnt have a bluetooth chip
Στάλθηκε από το Redmi Note 4 μου χρησιμοποιώντας Tapatalk
Latest 2.1 image has serious issues. Haven't seen anyone else mention it, so I figure it must be something I'm doing.
I cannot play anything because the GUI lags so bad. It takes 30+ seconds to move in the menu. I will outline the steps I'm doing to build my Rock64 with it.
1. Download latest image from here: http://le.builds.lakka.tv/Rockchip.ROCK64.arm/. Specifically this image: Lakka-Rockchip.ROCK64.arm-2.1.img.gz
2. Uncompress image with 7-zip, place image on Desktop.
3. Use Etcher to burn image to SD card
4. Boot Rock64, see expand filesystem message. Reboot
5. See GUI. "Waves" background similar to PS3 is not moving.
6. Move down to select "Shut down". Wait 30+ seconds before it moves. Might move 2 spots, might do 3 depending
7. Lag again for 30+ seconds. System catches up and finally moves another 2-3 spots.
8. Get frustrated and shut down Rock64 with power button.
9. Remove SD card with Lakka on it, replace with Android card. Boot.
10. Enjoy full use of my Rock64.
So what am I doing wrong?
just because an image is the latest does not mean it is the best. if you want to run lakka test several previous builds. if they are the same then let the package author/maintainer know about it and ask for a fix. since lakka is fairly new i'd be surprised if it worked very well.
Thats very weird. Did you change anything in the theme? Have in mind that some options in retroarch can easily kneel the rock64 gpu.
Hi dudemo, your Android Card is another microSD Card? Can it be that your Lakka's microSD Card is not performing well?
I have tested Lakka on SAMSUNG EVO microSD for quite some time to write this http://wiki.pine64.org/index.php/Lakka, so far did not hit any of your problem.
Enjoy!
Hi
Yes I understand it does not have Bluetooth.  I have the usb Bluetooth adapter
        Manufacturer: Cambridge Silicon Radio (10)
I have now been able to do all the Bluetooth config tutorial.  My controllers now connect.  The issue now is that they do not do anything.  It connects to the Bluetooth adapter but Lakka does not recognize my controllers.  I have my autoconfig of both Dualshock4 and Steelseries Stratus XL controllers in /tmp/joypads but Lakka will not recognize either of them.  Under Input -> User 1 Device Index it shows N/A for ports #0-3.
My DualShock4 does not show up in dmesg at all
The other controller is being shown as a keyboard on Bluetooth, but works fine on USB.
Mupen64plus crashes immediately when I try to launch games, anybody else experiencing this? Parallel works but performance is not good at all in anything except lowest possible resolution. Appreciate any feedback!
(01-28-2018, 06:02 PM)Mrfixit2001 Wrote: Mupen64plus crashes immediately when I try to launch games, anybody else experiencing this? Parallel works but performance is not good at all in anything except lowest possible resolution. Appreciate any feedback!
Yep same issue.
ETA Prime made a video on the Lakka build. Interestingly, he had mupen running on his board just fine.
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 218 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 4,180 01-24-2026, 04:44 PM
Last Post: ff255
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 11 16,576 12-06-2025, 01:32 PM
  Xen hypervisor on Rock64 tumbleweed 6 10,344 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,585 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,698 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,858 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 75,474 09-01-2024, 06:43 AM
Last Post: RaymondDay
  Rock64 v2 - did not work song / audio sqw200zu 2 5,117 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,802 12-27-2023, 10:34 AM
Last Post: dstallmo
