Which OS will you install into your Pine 64 (can select more than 1 if multiboot)?
Remix OS
21.88%
28
Linux: Ubuntu, Archlinux, Debian...
55.47%
71
Windows 10 IoT
5.47%
7
OpenHab
3.91%
5
Other (explain)
13.28%
17
128 vote(s)
Which OS will you install into your Pine 64?
Ubuntu & Andriod for me. two separate memory cards for each.
I would love to run stock Debian on it; but it doesn't seem like it s gonna be possible for a while :-(
(03-11-2016, 01:33 AM)antx0n Wrote: I would love to run stock Debian on it; but it doesn't seem like it s gonna be possible for a while :-(
https://github.com/umiddelb/z2d/blob/mas.../README.md
I'm running stock Debian (based on debootstrap and @longsleep's boot loader and kernel) on my PINE64, see here for more details.
Lol, that was a short while Wink
Android Big Grin
Thanks guys, I'll look into it, not convinced by RemixOS for now.
Ubuntu is installed and running, and it's currently a minecraft server, so it'll stay as it is. If I feel the need to play with anything else, I'll order another board.
#19
My primary reason for buying the pine is the same as many boards of its nature:
1) what can i do with the gpio
2) can it do pps on the gpio for ntp relatively accurately (the pine has 2 very attractive qualities for this; gig ethernet thats not on usb and should have very accurate gpio)
3) how well would it go as a server in various roles
4) how much performance you can get out of it as a router.
For some reason high accuracy time keeping has been something i cant seem to lose interest in, and these days its kinda harder to do it with off the shelf hardware then it used to be (ironically). The older serial connections on x86 used to be perfect, but more modern ones actually cause accuracy issues. The RPi's have become a popular platform for it due to how popular the platform is in general and how cheaply it can be done, but the rpi has usb connected 100m ethernet (both of which degrade its accuracy). The RPi can be out-gunned by an even cheaper and much lower spec'd chip  in the atheros ar9331, but 100m holds it back a little and sometimes the lack of grunt can be a minor issue. The Pine should be just about perfect, i hope.
#20
For me, probably, "All of the Above". Smile
As a systems integrator at my normal 9-5 job, I like to check out and tinker with all possibilities of a hardware platform to find the most optimal hardware/OS combination that would meet my needs.
  Pine a64+ power supply davidspencer 0 388 03-18-2026, 01:02 AM
Last Post: davidspencer
  Pine A64+ lost 7" screen functionality after kernel 6.1 Learnincurve 0 873 12-10-2025, 09:03 AM
Last Post: Learnincurve
  Pine 64 installer OS list blank spamsucks 1 12,380 04-08-2025, 08:16 AM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 5,646 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 3,054 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 9,502 07-03-2022, 02:18 PM
Last Post: Dude
  Install OpenWrt on A64+ without serial? JuniperFury 5 11,977 12-25-2021, 10:31 AM
Last Post: guenther
  Pine A64+ vs LCD do not boot DDS 3 10,061 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 7,117 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 7,419 01-18-2021, 03:45 PM
Last Post: squidius
