First Lakka image for Rock64!
(11-16-2017, 09:01 AM)KryPtAlIvIaN Wrote: In the past, I've copied and pasted the config values from your controller config file into the retroarch.cfg and it worked. Have you restarted?
Yea. Ok will copy the values over and try again. Will have time in a couple of hrs,  but will report back after trying.
Both I and YC tried different controllers - autoconfig points to /tmp/joypads where the controllers xinput are present. But only some controllers are recognised while others aren't (I only got Xbox 360 and 8Bitdo controllers to work).
I would tell Ntemis about that.
(11-17-2017, 09:55 AM)KryPtAlIvIaN Wrote: I would tell Ntemis about that.
Ok, will you get in touch with him ? You mentioned you're in their IRC ?
Sure can.
try to set joypad driver in menu to udev. Sounds like its on xinput and that input doesn't have nearly as many config files.
Its in udev by default, I managed to get the controller working by setting joystick driver to HID
edit: still, strange that udev would fail to recognise the controller like this ...
edit: hid only recognises some buttons on the controllers. Very strange.
Hello, just jumped over to inform you guys that Lakka v2.1 final is out with Retroarch v1.6.9.
Let me know if anything comes up Smile
Enjoy!
(11-22-2017, 03:53 PM)Ntemis Wrote: Hello, just jumped over to inform you guys that Lakka v2.1 final is out with Retroarch v1.6.9.
Enjoy!
Glad to see you in the forum :Smile Have a read of the thread please - my only complaint was that many common controllers were not recognised, otherwise great. I will check out the new image tomorrow.
Enjoy!
Controller issues should be gone by now Smile
Enjoy!
Excellent - will check it out first thing after I get back from work.
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 3,366 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 91,415 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,976 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,619 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,777 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,743 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,622 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,802 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,698 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  Rock64 v2 - did not work song / audio sqw200zu 2 6,134 03-14-2024, 03:09 AM
