USB GPS dongles that work with Android on Pine64+ ?
Hi
Have anybody got any usb gps dongles to work with android on Pine64+? I would love to have positioning to work on my Pine64 with touchscreen. If anybody have tried it and got it to work, it would be nice to know Smile
Trond Kjetil
This USB GPS library works at Android.
.zip   Android_GPS_lib64.zip (Size: 13.29 KB / Downloads: 805)
(09-25-2017, 05:09 AM)trondkj Wrote: Hi
Trond Kjetil
I got a bu-353 GPS working with an app and mock position.
The gps did not show up as an tty device, so i could not get the Android_GPS_lib64 working.. Smile
I used this lib to read the serial.
https://github.com/felHR85/UsbSerial
Then this NMEA parser to parse the data from serial to something readable:
https://gist.github.com/javisantana/1326141
In android manifest the following permissions should be set:
<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION" />
<uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION" />
<uses-permission android:name="android.permission.ACCESS_MOCK_LOCATION" />
I used Androids LocationManager to make a mock position.
On the device i had to enable developer mode (Settings -> About tablet, click 7 times on "Build number"), and then allow my app to set mock position in settings -> developer options.
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,678 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 609,199 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,322 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,109 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,736 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,324 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,607 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,777 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 410,173 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,551 02-26-2019, 11:58 AM
Last Post: Twistedx
