First Lakka image for Rock64!
Smile
[edit 04/06/2018]: As Ntemis pointed out, newer Lakka nightly builds can be downloaded for the Rock64 from here.
The good people at Lakka have released an image for the Rock64.
Please download it directly from their server.
Its a good day! Smile I can't wait to try tonight.
I have just try out and this is awesome !!!
does joypad/joystick work well?
(11-15-2017, 05:37 PM)dkryder Wrote: does joypad/joystick work well?
Most of my retro controllers worked fine (among them 8Bitdo NES30 Pro and Buffalo SNES) and so did generic and authentic Xbox 360 controllers. PS3 SixAxis controller didn't work.
To add to Luke's comment, I could not make my Xbox One controller work, nor did my Logitech F310 USB controller. However my NES30 Pro and my Mayflash GameCube to USB adaptor and WaveBird controller worked fantastically.
Thanks dudemo, just signed up on their forum to relay this to the developers.
Edit: iNNEXT controllers don't work either
You need to just copy over the config files from the master github. I'll search and then post
Wiki - http://www.lakka.tv/doc/Input-settings/
Github with files - https://github.com/libretro/retroarch-jo...aster/udev
(11-16-2017, 07:11 AM)KryPtAlIvIaN Wrote: You need to just copy over the config files from the master github. I'll search and then post
Huge thumbs up!
still doesn't recognise those controllers
In the past, I've copied and pasted the config values from your controller config file into the retroarch.cfg and it worked. Have you restarted?
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 3,053 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 90,720 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,834 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,555 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,695 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,652 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,577 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,756 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,666 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  Rock64 v2 - did not work song / audio sqw200zu 2 6,103 03-14-2024, 03:09 AM
