No USB Power after Login (ROCK64+Mate)
#31
(10-11-2017, 01:53 AM)mshock Wrote: Just reseived my ROCK64, installed the Debian LXDE 20170809 to microSD card, booted. USB keyboard and mouse (connectred to USB 2.0) worked before login/password window, but then mouse and keyboard stopped working.  Tried to connect my mouse and keyboard via an active USB hub with the same result!
They work with stock Android image, but not stable.
May the problem be in the insufficient power supply? - I use 2.5A PSU.
if you have not tried a recent build of linux by ayufan, try one of those.
(08-17-2017, 04:52 AM)MarkHaysHarris777 Wrote: Basically,  on the production boards they tied the usb power through regulators;  two GPIO lines must be toggled to set the regulator or the usb power drops.  For some reason the gpio mux lines controlling the regulators are left floating;  not good.
There are two ways to fix it:  1) dts|dtb , or script , to toggle the mux lines turning the regulators ON,  or 2) mod the board so that the regulators are ON all the time !
The regulators are on the schematic on page 19;    We'll do some testing and see if we can get a software fix;  otherwise, we'll put up a board mod procedure.
Blush
HI
   I am having problems with the USB 3.0 port and my external self-powered HD, wireless mouse and keyboard. Frequently, at boot, the Rock64 behaves like it forgets it has a mouse and/or hd. These devices work flawlessly with my PI III so I do not understand what's going on with my Rock64. Do you have any idea on how to fix this? I used the stock linux. Thx
I have the same problem...
Any solution for this?
Regards
(12-17-2017, 06:21 AM)cpocarlos Wrote: I have the same problem...
Regards
Support told me:
After consult internally, it seems that earlier OS build may having issue on controlling the USB power regulator.
Please download PINE64 installer, select"ROCK 64", the select "Community Xenia Mate" OS buildand burn the microSD card. Make sure the microSD card program successfullywithout error, plug into your ROCK64 board and power on.
Here is the PINE64 installer download link: https://github.com/pine64dev/PINE64-Inst...d#download
Things got much better
Regards!
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,955 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,382 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,151 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,212 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,808 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,840 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,107 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,309 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,177 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 119,457 09-01-2024, 06:05 AM
Last Post: RaymondDay
