Connecting USB 3.0 Flash Drive with exFAT format
I have a ROCK64 4 GB Model with 64 GB eMMC
I installed the android-7.1-rock-64-rock64_atv-v0.3.4-r86-update.zip using Android Tool from a Windows machine.
I'm using a 128 GB USB 3.0 Flash drive connected to the USB 3.0 port but it doesn't seem to detect the flash drive.
I started experimenting with other android images using 64 GB micro SD and one version recognized the disk, but want to reformat to be able use the same.
Has anyone tried connecting a USB 3 flash drive and had this working? Please help
i have used a 16GB flash drive and a 250GB hard disk with no problems in rock64 usb 3 port. you might want to check that drive is formatted to FAT to begin with. this should cause the fewest potential problems until you discover what other formats will work
(09-27-2017, 05:11 PM)dkryder Wrote: i have used a 16GB flash drive and a 250GB hard disk with no problems in rock64 usb 3 port. you might want to check  that drive is formatted to FAT to begin with. this should cause the fewest potential problems until you discover what other formats will work
Thanks! I tried 16GB and 32GB flash drive formatted in FAT32 format and it works!! I'm not sure why my USB 3 CORSAIR 128 GB flash drive is not working.
  Got an error message when trying to flash the Rock64 OS ilan 0 3,696 06-29-2020, 04:53 PM
Last Post: ilan
  Download IDB fail when trying to flash Android image cherkasoff 0 8,957 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Rock64 problems with external Hard Drive and powering mjd 1 4,934 12-14-2019, 10:05 AM
Last Post: helsinki92
  flash image to sd/emmc through ethernet LMM 0 3,881 02-04-2019, 07:36 AM
Last Post: LMM
  No Boot, Red Green and White flash at 1 sec intervals wesleykonrad 2 6,792 01-28-2019, 11:54 PM
Last Post: wesleykonrad
  Slow SMB transfers when sharing encrypted USB drive - is my CPU the bottleneck? oealias 3 8,264 04-01-2018, 03:42 AM
Last Post: pfeerick
  UBOOT flash to SPI R@nchito 0 2,890 02-25-2018, 08:54 AM
Last Post: R@nchito
Exclamation not able to flash u-boot onto SD Card consoleadam 2 7,155 02-16-2018, 06:43 PM
Last Post: gene83
  Unable to flash Android TV on eMMC: rkflashtool error fbossi 3 9,259 02-02-2018, 08:37 AM
Last Post: dannyboyw
  flash image directly to eMMC? gmruiz 4 10,828 01-09-2018, 05:43 AM
Last Post: Luke
