How to Write an Image to the eMMC Module Tutorial
#21
(08-15-2017, 05:31 AM)MarkHaysHarris777 Wrote: Greetings,
The purpose of this post is to document the procedure for writing gnu+linux images to the eMMC module on the Rock64 board; the procedure is fairly straight-forward and is not difficult with some small planning and care. First I'll give just a little discussion of the overall theory, then list the materials that you will need, and finally we'll cover the step-by-step detail.
Ehi Mark! Wink
Can you add pics to the guide for make it more readable? Please  Angel
#22
(08-30-2017, 01:20 PM)tarlo766 Wrote: Experienced IT guy here, but noob to SBC. I just wanted to make sure I got this right.
Do I need a serial terminal to install Android to the eMMC or just to install linux to the eMMC? (per fire219 on 08-15-2017, 02:05 PM).
If so does the CP2102 module USB to 3.3V TTL referenced in the tutorial require soldering to the rock64?
if so are their guides for it? Thanks for the support.
I can answer your second question. The USB to serial adapter does not require soldering. It simply attaches to the pins on rock64. The end of the adapter is a dupont connector so it can easily slide on and off the pins.
Sent from my XT1254 using Tapatalk
#23
Ehi Mark! Wink
Hey Boia11, There are pictures in the hyperlink to the serial tutorial included. Is there something specific you need pictures of that is not included there? I'm sure I can snap a couple if need be.
#24
I got my TTL to USB adapter today with the CH340 chip, I did every step according to the tutorial but I just get this on the console (using baud rate 150000):
[01:08:36:617] <break> [01:08:42:620] <0xfa><break> [01:08:55:692] <0xfc>␊
#25
(08-31-2017, 05:11 PM)Lexstar Wrote: I got my TTL to USB adapter today with the CH340 chip, I did every step according to the tutorial but I just get this on the console (using baud rate 150000):
yeah, its not baud 150000.
...  its 1.5M  1500000
Please count the zeros.
#26
I believe the baud rate is actually 1500000  --I think you are missing a zero.....
#27
Why installation is not done by just like this:
1) insert an SD card card with the "minimal" linux.
2) snap an empty eMMC in
3) turn the board on, boot from SD
4) download an image and flash it into eMMC by that smartass script.
I know it's obvious and hardly nobody could think of it before, rather there are some obstacles to do so. What they are?
ANT - my hobby OS for x86 and ARM.
#28
Did not work for me but basically did the same with an additional step and then succeeded.
downloaded ayufan image and burned to sd
booted from sd
deleted partition on "brand new" emmc using fdisk
created a new partition using fdisk
created filesystem using mkfs
dd image to emmc
BUT since then I do have a message
blk_update_request: I/O error, dev mmcblk0rpmb, sector 0
in syslog which I'm a little bit scared of.
#29
(09-03-2017, 07:43 AM)z4v4l Wrote: Why installation is not done by just like this:
Hi, the reason your simplified approach will not work is that boot precedence and eMMC initialization create two problems which prevent it.  If there is an image on the eMMC already, then the eMMC will boot 'first'.  If there is no image on the eMMC then either the machine will not boot, or if it does boot,  both devices will not be 'seen' by the OS during initialization; both mmcblk0 and mmcblk1 must be present, AND the machine has to be booted from SD.
The jumper used has one function,  it grounds the clock line of the eMMC, deactivating it temporarily;  that way the SD card will boot-up because (for all intents and purposes) the eMMC is not there.  We interrupt the boot-up at the uboot timer and then continue the bootup with the jumper removed--  this allows the boot-up to continue on SD, but also allows the OS to 'see' the eMMC module during initialization.
Thanks for the question.
#30
Seems I'm missing something here because
booted from sd
rock64@rock64:~$ /usr/bin/hostnamectl   Static hostname: rock64         Icon name: computer        Machine ID: ba551e15e1de486494c058b5367a1a09           Boot ID: 57ff54573ab34ebc8ac34780bb3a95dd  Operating System: Debian GNU/Linux 9 (stretch)            Kernel: Linux 4.4.77-rockchip-ayufan-92      Architecture: arm64           rock64@rock64:~$ lsblk NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT sda            8:0    1 29.8G  0 disk `-sda1         8:1    1 29.8G  0 part mmcblk1      179:0    0 29.8G  0 disk |-mmcblk1p1  179:1    0  3.9M  0 part |-mmcblk1p2  179:2    0   64K  0 part |-mmcblk1p3  179:3    0    4M  0 part |-mmcblk1p4  179:4    0    4M  0 part |-mmcblk1p5  179:5    0    4M  0 part |-mmcblk1p6  179:6    0  112M  0 part `-mmcblk1p7  179:7    0    1G  0 part / mmcblk0      179:32   0 28.9G  0 disk |-mmcblk0p1  179:33   0  3.9M  0 part |-mmcblk0p2  179:34   0   64K  0 part |-mmcblk0p3  179:35   0    4M  0 part |-mmcblk0p4  179:36   0    4M  0 part |-mmcblk0p5  179:37   0    4M  0 part |-mmcblk0p6  179:38   0  112M  0 part /boot/efi `-mmcblk0p7  179:39   0 28.8G  0 part mmcblk0boot0 179:64   0    4M  1 disk mmcblk0boot1 179:96   0    4M  1 disk mmcblk0rpmb  179:128  0    4M  0 disk
booted from emmc
rock64@therock:~$ hostnamectl  Static hostname: therock        Icon name: computer       Machine ID: 3b727929d77847c5834cba2762c208f7          Boot ID: 64466c4d78084c9ba2b84b9e73afefe1 Operating System: Ubuntu 16.04.3 LTS           Kernel: Linux 4.4.77-rockchip-ayufan-92     Architecture: arm64         rock64@therock:~$ lsblk NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT sda            8:0    1 29.8G  0 disk └─sda1         8:1    1 29.8G  0 part mmcblk0rpmb  179:96   0    4M  0 disk mmcblk0boot0 179:32   0    4M  1 disk mmcblk0boot1 179:64   0    4M  1 disk mmcblk0      179:0    0 28.9G  0 disk ├─mmcblk0p1  179:1    0  3.9M  0 part ├─mmcblk0p2  179:2    0   64K  0 part ├─mmcblk0p3  179:3    0    4M  0 part ├─mmcblk0p4  179:4    0    4M  0 part ├─mmcblk0p5  179:5    0    4M  0 part ├─mmcblk0p6  179:6    0  112M  0 part /boot/efi └─mmcblk0p7  179:7    0 28.8G  0 part /
Can you enlight me?
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,753 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 7,137 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 7,412 08-19-2021, 06:46 PM
Last Post: bcnaz
  Download IDB fail when trying to flash Android image cherkasoff 0 9,031 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Receiving errors about eMMC (?) acasta 11 27,712 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 49,793 07-27-2019, 04:27 PM
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 3,691 02-05-2019, 05:41 PM
Last Post: ictele
  flash image to sd/emmc through ethernet LMM 0 3,943 02-04-2019, 07:36 AM
Last Post: LMM
  HW image transitions in Python gaggleoxfoggy 7 13,717 11-24-2018, 10:41 AM
Last Post: gaggleoxfoggy
  Rock64 Compute Module ktc 5 12,150 08-24-2018, 03:23 PM
