Eth0 dhcp issues
Pretty often at boot time my eth0 does not get an DHCP address assigned.
I have to play with
sudo dhclient
sudo ifconfig eth0 down
sudo ifconfig eth0 up
between 2 and 5 times to finally get network configuration from DHCP server.
Is it a known issue on Linux (happens on most images I have tested) ?
I have seen a similar thread on Android.
Well at least since latest ayufan fixes (0.5.1 images) we always get the same MAC address Smile
I'm seeing the same problem on production board. It does not happen on pre-production Smile
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
Since yesterday I've booted my sbc 51 times and did not encounter this issue once.
My current setup is:
Rock64 4GB
Ethernet eth0 connected to router which offers dhcp service
MicroSD and emmc plugged in but only SD used (ayufans 64bit mate image v0.5.4 installed)
No mouse, keyboard and monitor connected - working over ssh terminal.
Hope that this helps to identify the cause of the problem.
Regards
Reinhard
I have mitigated (fixed ?) the issue by disabling IPv6.
Hmm, I'm not seeing it too. It was a false alarm.
Releases:
Buy me a Beer
(08-30-2017, 02:45 AM)LTronic Wrote: I have mitigated (fixed ?) the issue by disabling IPv6.
And how is that done? I'm out in the sticks, 100 miles from the nearest ipv6 capable port.
  USB3.0 Issues at DietPi(Armbian) #22.02.1 t4_4t 3 5,954 08-15-2022, 06:58 PM
Last Post: TRS-80
  csdr build issues. TravisH 0 3,602 02-19-2020, 04:47 AM
Last Post: TravisH
Rainbow USB3 Detection Issues When Booting Without USB Device Attached Dargmuesli 0 3,505 01-14-2019, 11:26 AM
Last Post: Dargmuesli
  Seedbox issues (rtorrent, rutorrent, autodl-irssi) va88 5 13,145 12-16-2018, 10:59 AM
Last Post: va88
  Arch Linux USB3 Issues? decontainerized 4 12,702 07-25-2018, 04:39 AM
Last Post: cooker
  monitor setting & keyboard issues gpine1 2 5,776 05-27-2018, 03:51 PM
Last Post: Luke
