Daughter Card SBC for P64
I dunno if any of you remember, but in the 90's and 2k's you could buy a single-board computer that slotted into an ISA or PCI slot and acted as a very, very expensive watchdog for big servers. Well, history is repeating itself: here's a pi zero acting as a daughterboard for a pine64. Big Grin
[Image: MhtIJU.jpg]
(08-21-2017, 12:41 PM)blue Wrote: I dunno if any of you remember, but in the 90's and 2k's you could buy a single-board computer that slotted into an ISA or PCI slot and acted as a very, very expensive watchdog for big servers. Well, history is repeating itself: here's a pi zero acting as a daughterboard for a pine64. Big Grin
[Image: MhtIJU.jpg]
can you explain the uses of this daughter board thing.. Angel
[Image: MhtIJU.jpg]
He just added four more A53 cores to his PineA64 board;  the daughter card can now interact with the PineA64 (maybe) for extended SMP computing, but probably he's got monitor|watchdog in mind here;  the PI can "operate" the PineA64 directly... and there might be some interesting things one might do with that !
Depends what he does with the gpio(s) on both boards, whether they work together or not, or whether there is blue smoke and suffering.
Blush
the pi zero looks to me like it was just positioned on the pine64 for a picture. lack of solder joints.
(08-22-2017, 04:52 AM)dkryder Wrote: the pi zero looks to me like it was just positioned on the pine64 for a picture. lack of solder joints.
heh hehe   and you wouldn't want the 3v3 soldered anyways...  if you were really going to do this some of the underside pins would | should be cut ;
Shy
I have no plan of powering it on, I just thought it was hilarious that it's a perfect fit. You can actually slide two zeroes on the bus if you squish em.
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 6,974 05-19-2023, 07:43 AM
Last Post: crocspot
Exclamation Can't boot when SD card inserted kivox 5 13,464 03-15-2020, 06:00 AM
Last Post: kivox
  Pine64 $15 card killed my $120 keyboard exa 22 46,393 01-04-2017, 09:01 AM
Last Post: skenn_ie
  overlapping partitions issue with resize of 8GB image put on 16GB sd card dkryder 10 20,655 10-05-2016, 11:32 AM
Last Post: dkryder
  SD card recovery TeaPack 8 14,968 08-07-2016, 07:35 AM
Last Post: xalius
  Can't write to SD card w/ Adapter apple4ever 2 7,046 07-23-2016, 03:16 PM
Last Post: apple4ever
  missing SD card xj-boonie 4 10,226 07-13-2016, 12:22 PM
  128GB Card OS? mesaxi 12 27,530 07-12-2016, 11:59 PM
Last Post: Tarjei85
  Problem making SD card Tam Dl 17 34,529 06-19-2016, 07:48 PM
Last Post: pfeerick
  Missing SD Card Chris_Mc11 0 2,993 04-26-2016, 06:02 PM
Last Post: Chris_Mc11
