How to Write an Image to the eMMC Module Tutorial
Mark, excellent. Thank you.
Sent from my XT1254 using Tapatalk
(08-15-2017, 12:05 PM)MarkHaysHarris777 Wrote: I also have ported ayufan's script to the rock64 -- rock64_install_to_emmc,  which further simplifies things by allowing the user to select the system and version, as well automatically generating the curl file;  very nice.
Does the script automatically interrupt the uboot timer or is it just for everything after step 6?
The script helps only after the SD is fully booted;  well, its a gnu+linux bash script, it doesn't work at boot-up.  Interrupting uboot is manual, based on the feedback received on the serial console alone.
I have updated this thread with the information from this link:
Shy
Would you see the same output from a monitor if you do not have a serial cable? I am just wondering whether you can get away with that approach.
Sent from my SM-T537V using Tapatalk
(08-16-2017, 06:32 AM)jl_678 Wrote: Would you see the same output from a monitor if you do not have a serial cable? I am just wondering whether you can get away with that approach.
From the guide (with emphasis):
MarkHaysHarris777 Wrote: The serial console is very important because the normal display does not show boot-up messages!
Technically you could try to time it blind, but unless you already know how the boot output over serial looks you are unlikely to get it right.
Sorry, I read it too fast. Thank you.
(08-16-2017, 08:28 AM)fire219 Wrote: Technically you could try to time it blind, but unless you already know how the boot output over serial looks you are unlikely to get it right.
Yesterday I tried to it blind.
When I removed the jumper 3 seconds after turning on the power, writing the image succeeded.
However, this method may be dangerous. Then I will try to it by using a serial adapter (CP2104) tonight.
#19
Well done. It's definitely not impossible to do, it's just a bit difficult.
Also, welcome to the forums. Smile
#20
Experienced IT guy here, but noob to SBC. I just wanted to make sure I got this right.
Do I need a serial terminal to install Android to the eMMC or just to install linux to the eMMC? (per fire219 on 08-15-2017, 02:05 PM).
If so does the CP2102 module USB to 3.3V TTL referenced in the tutorial require soldering to the rock64?
if so are their guides for it? Thanks for the support.
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,753 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 7,137 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 7,412 08-19-2021, 06:46 PM
Last Post: bcnaz
  Download IDB fail when trying to flash Android image cherkasoff 0 9,031 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Receiving errors about eMMC (?) acasta 11 27,712 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 49,793 07-27-2019, 04:27 PM
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 3,691 02-05-2019, 05:41 PM
Last Post: ictele
  flash image to sd/emmc through ethernet LMM 0 3,943 02-04-2019, 07:36 AM
Last Post: LMM
  HW image transitions in Python gaggleoxfoggy 7 13,713 11-24-2018, 10:41 AM
Last Post: gaggleoxfoggy
  Rock64 Compute Module ktc 5 12,148 08-24-2018, 03:23 PM
