Switch inside the case
I wonder what the switch inside the case on motherboard does? Also I'd like to know what the small button does? I assume it's battery disconnect.
I haven't opened mine yet, but there should be a switch there to switch the headphone jack towards UART0 (Serial console for U-Boot and linux)
A button? Most likely a reset button. But I haven't checked the schematics.
(08-13-2017, 07:02 AM)daid Wrote: I haven't opened mine yet, but there should be a switch there to switch the headphone jack towards UART0 (Serial console for U-Boot and linux)
Oh are there public schematics somewhere? I'd love to see them.
The switch is to turn on UART via headphone jack (UART0 is multiplexed with audio) for debugging and OS development, the pusbutton is to enter A64 FEL (bootloader) mode, the schematics and other docs are here: https://www.pine64.org/?page_id=5734, for datasheets check the wiki http://wiki.pine64.org/index.php/Main_Pa...eripherals
  UART switch Pinebook 11.6" irongarment 3 8,926 01-03-2022, 03:28 AM
Last Post: kqlnut
  Case crack ImmortanJoe 18 44,366 10-17-2020, 01:55 AM
Last Post: Mick
  Case Mod Opening for Serial Console Slider Switch MarkHaysHarris777 1 11,023 11-21-2018, 11:14 AM
Last Post: machinehum
Exclamation Pinebook uart(0) Slider Switch Enable -- Disables left-hand USB Port MarkHaysHarris777 1 4,491 08-27-2017, 10:30 AM
Last Post: MarkHaysHarris777
  Thermal pads inside were installed the wrong way hene 6 12,824 08-24-2017, 10:42 AM
Last Post: schepers_cp
  Does the case take paint? combs 4 8,934 08-08-2017, 03:06 PM
Last Post: combs
  What is the little switch for? AndyK 4 9,532 06-20-2017, 10:33 AM
Last Post: AndyK
