Pine64 doesn't recognize Wifi/BT Module
I have two Pine A64 boards, one with 1GB RAM and one with 2GB. I plugged the Wifi/BT module into the 1GB board but accidentally plugged it in off by one pin on the connectors. The board booted up, but restarted a couple of times before finally coming up. Naturally, it did not recognize the Wifi module. When I saw my mistake, I removed power and repositioned the module. It still did not recognize the module. I tried plugging the module on the 2GB board and it worked fine. I tried the module I originally had on the 2GB board on the 1GB board and it didn't recognize that one either.
So final result: the 2GB board sees both Wifi/BT modules, but the 1GB board doesn't see either one. I'm guessing I smoked the interface on the 1GB board. Everything else appears to be working on it so far. Has anyone else experienced this?
(07-13-2017, 07:11 PM)clobeca Wrote: I have two Pine A64 boards, one with 1GB RAM and one with 2GB. I plugged the Wifi/BT module into the 1GB board but accidentally plugged it in off by one pin on the connectors. The board booted up, but restarted a couple of times before finally coming up. Naturally, it did not recognize the Wifi module. When I saw my mistake, I removed power and repositioned the module. It still did not recognize the module. I tried plugging the module on the 2GB board and it worked fine. I tried the module I originally had on the 2GB board on the 1GB board and it didn't recognize that one either.
Yes, sadly.  You might try another wifi module ? More likely than not you managed to damage the 1G board;  don't worry about it, just get another one;  you may notice other strange things coming from that board in the future;
Thanks for the quick reply. Yes, I have two Wifi modules. Both of them work on the 2GB board, and neither one on the 1GB. Another board it is!
(07-13-2017, 08:53 PM)clobeca Wrote: Thanks for the quick reply. Yes, I have two Wifi modules. Both of them work on the 2GB board, and neither one on the 1GB. Another board it is!
well, ok,   rats.
We had another person recently have this issue, and later the 1G board started acting up in other areas, so expect that too;  the boards are inexpensive enough that you can make this mistake and not lose much;  just order another one;  only get the 2G board !
  [split] Better WiFi/BT module? moriel5 3 10,638 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,809 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 43,416 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,278 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 33,910 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 16,886 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 3,603 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 6,207 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,882 02-21-2018, 09:56 PM
Last Post: dkebler
Sad wifi direct bj_jung 2 8,538 12-29-2016, 10:26 AM
Last Post: happytuna
