Xenial Mate (Pinebook) 20170505
Wireless seems to have some kind of weird issue occasionally when coming back from a suspend.  I've only experienced it twice lately, but seems like the panel applet shows the connection as a wired connection sometimes (seems to still work though) but you won't be able to switch to another SSID when its in that state.
(05-10-2017, 10:21 AM)pagesix1536 Wrote: Wireless seems to have some kind of weird issue occasionally when coming back from a suspend.  I've only experienced it twice lately, but seems like the panel applet shows the connection as a wired connection sometimes (seems to still work though) but you won't be able to switch to another SSID when its in that state.
On the newest image ?
How is video running in this image? youtube, netflix?
(05-10-2017, 12:17 PM)Pirolocito Wrote: How is video running in this image? youtube, netflix?
Poorly. If you want that sort of stuff, then go with android. I am glad to say however that SMplayer works great with some tweaks. 1080p plays back smooth as butter for the most part.
hi, wireless (nor any other connection) can come back from suspend;  suspend by definition breaks the connection.  Waking up from suspend must reconnect; not sure about the icon though.
I have noticed the opposite ;  sometimes the wired connection appears briefly on the tool-bar as wireless!  ... not often.
Yep...the one from the 5th.  I'll see if I can snag a screenshot when I see it happen next.
Youtube is ok if you don't go full screen.  I wouldn't rely on your Pinebook to be a TV/Movie watching device.  Luke's right though, the Android images seem to be far better for performance, even at full screen video was good.  Linux won't be awesome on this thing unless there's a proper X video driver for the hardware.  I think the Linux install is using a juiced up version of a FrameBuffer driver which historically is one of the most compatible you can get, but the most terrible for performance.  Plus the Mali400 isn't really all that awesome.  I kinda wish the would have at least put the Mali450 in the Pine hardware.
Wireless flipping to a wired adapter happened again.  Here's a screenshot. You can see the icon has changed.  When clicked, it shows "Wi-Fi Networks" greyed out and not accessible.  The connection still works, but you can't change anything with regards to it being a wireless connection.  From the command line, all looks well though.  Seems like just a bug with the panel applet maybe.
cmiller@pinebook:~$ nmcli d
DEVICE  TYPE      STATE      CONNECTION
wlan0   wifi      connected  Tardis
dummy0  dummy     unmanaged  --
sit0    iptunnel  unmanaged  --
lo      loopback  unmanaged  --
[Image: zVekbCp.png]
Ok, you're not the only one ... take a look here (hint, its on wifi)
Its still connected and works just fine.
Edit:  longsleep solved it. Restarting NM solves the problem:
systemctl restart NetworkManager.service
You can add this to prevent it from happening again in your current build.
The fix will be added to future iterations of the images.
#19
Awesome... I figured a restart would probably fix it, just hadn't tried it yet.
I setup the systemd service. Thanks for the tip!
#20
Quick note, if you want to update to a pre-release kernel (such as 0.5.1 at the time of writing) then add the kernel nr. after the kernel and uboot scripts, for instance:
sudo ./pine64_update_kernel.sh 0.5.1 sudo ./pine64_update_uboot.sh 0.5.1
Needless to say, pre-release stuff can have issues. This particular pre-release however is worth updating too as it allows you to run chromium as you normally would (which I recommend, as its much snappier than firefox)
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 5 15,170 10-25-2026, 04:11 AM
  DietPi OS for Pinebook MichaIng 5 18,038 07-28-2026, 08:02 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 106,569 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 6,245 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,735 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 17,512 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,745 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 11,099 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,849 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,774 01-20-2021, 11:18 AM
