Which OS will you be running on the Pinebook?
Linux
94.83%
55
Android
5.17%
3
58 vote(s)
BSP Linux woes, early adopter information and a poll
(04-23-2017, 11:53 PM)pfeerick Wrote:
(04-23-2017, 07:46 AM)Luke Wrote: Yes, I am pretty sure it senses the magnets in the lid (?). I am basing this assumption of this wikipedia article.
Thanks Luke and TL Big Grin
Luke, could you add something to that effect where you mentioned in the OP? Didn't want to be rude and edit on you Wink
And yes, a hall effect sensor is a solid state sensor for detecting magnetic fields, as opposed to a reed switch or other sensor. That's why I was wondering if it was for the lid or something else.
You are always welcome to edit my posts Smile
(04-22-2017, 10:32 AM)LordSuricato Wrote: Hello, in a few days I will go to some meetings and maybe a hackathon with the Pinebook 14 "and I am concerned about the failure of HDMI to do some presentation. Mini HDMI works on Android?
Thanks in advance, I expect a lot of Pinebook and Linux, and all the large community of developers of Pine64 / Linux
The Pinebook able to mirror image at HDMI output on both Ayufan (7.0 and 7.10 and vendor Android (6.0) build.
Out of curiosity, does sleep/ wake work on android ?
Has anyone had boot issues? I plug power in & the power LED just slowly flashes. Power button does nothing. After several minutes, the case around the power port gets VERY hot, like almost too hot to touch. I'm assuming there's a short somewhere in there. Unplug power and it cools down but no power LED flashing or anything. I opened a ticket yesterday but haven't gotten a response yet.
Thoughts?
(04-25-2017, 05:53 PM)bcupps Wrote: Has anyone had boot issues? I plug power in & the power LED just slowly flashes. Power button does nothing. After several minutes, the case around the power port gets VERY hot, like almost too hot to touch. I'm assuming there's a short somewhere in there. Unplug power and it cools down but no power LED flashing or anything. I opened a ticket yesterday but haven't gotten a response yet.
Thoughts?
Can you try open up Pinebook casing and reconnect the eMMC and Battery connector as shown below?
http://imgur.com/a/ZpCER
That's great! Thank you very much. According to DHL it arrives just in time for the Hackathon.
You can download the PINE64 Installer from
https://www.pine64.org/?page_id=5734
to install the OS into Pinebook eMMC.
Great,
Will make a post about it in each relevant section section.
#19
Thoughts?
After speaking with tllim on IRC today, I got home and did as you both suggested. No dice. I've sent tllim an email with photos and a short video showing what's going on. Thoughts?
#20
Hi all,
In current build, i forget to remove a command line in /etc/rc.local which cause the Bluetooth unstable. Thus, just delete "/usr/local/sbin/start_bt.sh /dev/ttyS1" in "/etc/rc.local" to solve it. And I will patch it into new build. Sorry for any inconvenient.
  Information about new Pinebooks junker 1 7,337 09-16-2020, 10:29 PM
  eMMC boot linux distros for Pinebook. frank-zappa 14 33,657 09-06-2019, 08:39 AM
Last Post: frank-zappa
  I need some summary information about hardware support by OS for a newbie tahf 10 23,615 01-25-2019, 10:01 AM
Last Post: tahf
  Poll: Which distro do you use for pinebook? erchache2000 2 7,695 09-12-2018, 12:36 AM
Last Post: Wizzard
Information Flood of basic linux questions skot 4 9,935 08-12-2017, 03:52 PM
Last Post: MarkHaysHarris777
Information Linux image with DRM + Mali Luke 1 10,438 08-05-2017, 10:49 PM
Last Post: abrmx
  ayufan's Linux and Android builds Luke 0 5,146 04-30-2017, 09:46 AM
Last Post: Luke
