PINE64 + mini OLED display + Luma.OLED = PINEimus Prime
First there was CHIPtimus Prime for the CHIP SBC. Then came ODROIDtimus Prime for the ODROID C series. Now there's PINEimus Prime for the PINE64. This will work for I2C displays only at this point. I wasn't able to get SPI fired up with legacy or mainline Armbian.
[Image: Ih2xMbN822pkac4EwGeqh8KhrUojySMvKs4uNi37...6-h1134-no]
Transform your PINE64 into a PINEimus Prime for projects requiring a small OLED display. Luma.OLED makes it easy to do text, graphics and video. Both displays I used to test I bought on Amazon. I already ordered some cheaper ones on EBay. I was able to get 3 SSD1306 I2C displays for under $10! I also ordered some TFT displays as well to test.
Requirements
Do the following for I2C version of SSD1306
The 4 wire DIY display can be powered by 3.3V or 5V which makes it handy if you need the other power source for something else. Wire mapping using i2c-0 (twi0):
VCC to VCC 5V   (pin 4)
GND to GND      (pin 6)
SCL to I2C1 SCL (pin 5)
SDA to I2C1 SDA (pin 3)
Configure I2C
  • Power off PINE64, wire up display and power on
  • sudo apt-get install i2c-tools
  • sudo usermod -a -G i2c username
Test I2C and display
  • i2cdetect -l
i2c-0    i2c           twi0                                I2C adapter
i2c-1    i2c           twi1                                I2C adapter
  • i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Time to install Luma.OLED
sudo apt-get install python-dev python-pip libfreetype6-dev libjpeg-dev
sudo -H pip install --upgrade pip setuptools
sudo -H pip install --upgrade luma.oled
I2C hello world
  • cd
  • nano i2chello.py
import time
from luma.core.serial import i2c
from luma.core.render import canvas
from luma.oled.device import ssd1306
serial = i2c(port=1, address=0x3C)
device = ssd1306(serial)
with canvas(device) as draw:
    draw.rectangle(device.bounding_box, outline="white")
    draw.text((3, 3), "Hello", fill="white")
time.sleep(10)
  • python i2chello.py
Then install examples
cd
sudo apt-get install git-core libsdl-dev libportmidi-dev libsdl-ttf2.0-dev libsdl-mixer1.2-dev libsdl-image1.2-dev
git clone https://github.com/rm-hull/luma.examples.git
cd luma.examples
sudo -H pip install -e .
Run example on I2C display
cd
cd luma.examples
python examples/invaders.py -d ssd1306 --i2c-port 1 --i2c-address 0x3c
Thanks for the tutorial, I may have a project that requires a small display...
(04-20-2017, 04:48 AM)xalius Wrote: Thanks for the tutorial, I may have a project that requires a small display...
Now if I can only get SPI/GPIO working I could get the SPI displays fired up. I just got SPI/GPIO configured on the ODROID C1 using a RPi.GPIO replacement module. I need something similar for PINE64.
there is a rpi-gpio for pine64 around. at least there was a while back. https://github.com/swkim01/RPi.GPIO-PineA64 i think there were some issues with this in getting it to work as expected. it does not appear to be under active development currently.
Yea, I looked around, but without a stable GPIO module it's impossible to get Luma.OLED working. I have it working on CHIP and ODROID C1 with the mono display, but the RGB SSD1331 is still giving me issues. I ordered a Pi 3, so I can use that as a base test since that what most GPIO code is written for.
  Pine64 as squeezebox touch replacement Learnincurve 12 40,076 01-13-2021, 02:11 AM
Last Post: Learnincurve
  Pine64 E-ink screen - Android projectileobjects 4 13,631 12-03-2020, 03:03 PM
Last Post: Silk
  Pine64 based IP KVM tuaris 0 6,193 08-06-2020, 12:05 AM
Last Post: tuaris
Information Pine64 Head Unit Zoidiano0 100 211,308 11-19-2019, 04:35 AM
Last Post: rogatip79
  PINE64 to allow use of SATA disk on network/FTP mwelbourne 10 24,508 11-18-2019, 04:09 PM
Last Post: evilbunny
  How to setup VNC on your Pine64 (Debian, SSH, headless) pine64nutz 20 58,950 04-16-2019, 08:00 AM
Last Post: hg6806
  Setup Pine64+ with OP-TEE stdys 0 5,633 09-13-2018, 03:23 PM
Last Post: stdys
Information UEFI for Pine64 z4v4l 20 59,292 06-24-2018, 03:06 PM
Last Post: z4v4l
  Domoticz + PINE64 Z-Wave Module + Open Z-Wave klliew 4 14,146 04-19-2018, 02:23 AM
Last Post: Harlan Mueller
  Pine64 as Security Camera / Baby Monitor utdrmac 2 10,412 02-01-2018, 07:49 AM
Last Post: davidbrucs
