Pine64 cannot boot
Question
My Pine64+(2GB) cannot boot with any linux image,but it can boot with android image,I use 5V2.5A power supply unit and 30 cm usb cable.
If it boots and runs Android images it should also run Linux images no problem, which image did you try?
Ubuntu 16.04 with Xfce DE and armbian,it can boot but not successful every time.All I get is a steady red LED and its Ethernet doesn't work.
(03-23-2017, 10:32 PM)jamiechang917 Wrote: Ubuntu 16.04 with Xfce DE and armbian,it can boot but not successful every time.All I get is a steady red LED and its Ethernet doesn't work.
If your board is powering on (red light), but the ethernet lights aren't showing signs of life after 20-30 seconds, it's probably worth looking at the power supply setup. See if you can use a good quality short USB lead. Try a different 5v power supply with at least a 2A rating (more is fine). If you feel up to it, try powering the pine64 via the euler connector (look at the pinout link in my signature) so we can eliminate the microUSB cable and connector as being an issue.
Thanks,I'll give it a try.
New guy here, but having a similar issue when booting or rebooting with an external hard drive attached. Boots ok without the drive. I disconnect the external drive and give the Pine a 20 second head start, then plug in the drive. The external drive has a seperate power supply and is spinning at all times.
You didn't mention if in fact you had anything plugged into the USB's. As mentioned above, my issue was a hard drive, but in theory, it could be anything ... even a keybaord, or mouse, exthernet cable, maybe even an HDMI monitor.
I'm too new to the product to know what the general consensus is on booting with anything attached.
W.
(04-16-2017, 09:50 AM)Dagremote Wrote: I'm too new to the product to know what the general consensus is on booting with anything attached.
Well, that suggests that powering the drive at least shouldn't be an issue, since it has it's own power supply. I often had a USB keyboard/mouse receiver plugged in when booting + HDMI when working on a pine64 prior to making it headless or when testing android / linux GUI stuff. Didn't have any boot hiccups that I would blame on them. I've had USB flash drives plugged in, but I can't be certain they were connected during a reboot or cold start. If you could plug in a 3.3v serial UART into the EXP header (pinout in my signature) you'd be able to capture the startup logs, and maybe get some idea as to why it's failing to boot... maybe there is some interaction during the bootup process that breaks things...
  Programming languages support under PINE64 baryluk 6 20,535 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,569 10-19-2019, 05:13 AM
Last Post: roel
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,690 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Volumio for PINE64 Released mikelangeloz 11 38,888 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,617 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,052 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 56,656 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,952 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,465 06-21-2018, 05:45 PM
Last Post: evilbunny
  Secure boot & OTP efuse program devangpanchal90 0 4,187 05-25-2018, 01:59 AM
Last Post: devangpanchal90
