use uvc as primary camera
@dkryder i tried your mod.
the file mentioned in the link you had given has a filed called camera.tegra3.so
i just copied the file and rebooted the device which did not seem to make any difference.
but when i checked pine64, it has a file called camera.tulip.so and not camera.tegra3.so
I also noticed that android 6 actually sets the UVC camera as the secondary camera device. So, when i selected the secondary camera in hangout, suddenly the video came alive. That pretty much was what i needed. But then again, ran into another problem. My UVC camera has a microphone which didn't seem to be used. So, my google hangout was without voice. Is there any setting to enable the microphone in the camera device?
(03-22-2017, 07:35 AM)mathiraj Wrote: @dkryder i tried your mod.
yes, that file was for a nexus 7 mod. you would need to rename it to the pine64 filename and also change any references inside the file to the appropriate pine64 reference. for that you will need a hex editor. my guess is it's not going to work with an outside chance to someone who has successfully used a hex editor before. as far as voice on google hangout i have never used it but i would suggest google search on the issue of no sound with google hangout and see if you can pick up any ideas
  Android USB camera support - Android 7.0 mikey0000 24 58,725 08-27-2018, 08:39 PM
Last Post: lee
  Camera Support Thru Android devildog125 17 33,968 12-04-2016, 09:42 AM
Last Post: kenjiru
  UVC Camera support mikey0000 6 14,494 09-09-2016, 01:49 PM
Last Post: mikey0000
  Camera streaming to TV over long distance CanadianIceTech 6 16,602 08-03-2016, 02:15 AM
Last Post: RangeR
Music RTC and Camera modules g_t_j 2 7,176 05-26-2016, 02:42 PM
Last Post: g_t_j
  Audio from Headphone Jack and Camera Issue cybernak 1 5,505 05-23-2016, 11:02 AM
Question Android + Camera Peripheral T_ech 4 11,110 01-29-2016, 10:01 PM
Last Post: modsbyus
