Create a WiFi hotspot on Debian 8
Hello together!
I tried something to create a WiFi hotspot with officially WiFi/bluetooth module by pine64 via ethernet and this is my solution.
Feel free to discuss about this topic Smile
Note: The WiFi hotspot is using the internet connection via ethernet. I wasn't able to bridge the internet connection from wlan0 to wlan1!
Note 2: I haven't installed NetworkManager on my system. NetworkManager can be responsible for problems with these instructions.
Install hostapd (create a hotspot), dnsmasq (dhcp server) and iptables-persistent (firewall settings)
apt-get install hostapd dnsmasq iptables-persistent
Change the config of hostapd
/etc/hostapd/hostapd.conf
interface=wlan0 driver=nl80211 ssid=MyPrivateHotspot hw_mode=g channel=6 macaddr_acl=0 auth_algs=1 ignore_broadcast_ssid=0 wpa=3 wpa_passphrase=MyVeryStrongPassword wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP rsn_pairwise=CCMP
Change the config of dnsmasq
/etc/dnsmasq.conf
no-resolv interface=wlan0 dhcp-range=10.0.0.3,10.0.0.20,12h server=8.8.8.8 server=8.8.4.4
Restart dnsmasq to apply the new config
/etc/init.d/dnsmasq restart
Activate forwarding of IPv4
/etc/sysctl.conf
Just uncomment the following line: net.ipv4.ip_forward=1
Apply it without reboot with the following command:
sysctl -w net.ipv4.ip_forward=1
Setup the network configuration
/etc/network/interfaces
auto lo iface lo inet loopback auto eth0 iface eth0 inet dhcp         pre-up iptables-restore < /etc/network/iptables.rules iface wlan1 inet manual auto wlan0 iface wlan0 inet static         address 10.0.0.1         broadcast 10.0.0.255         netmask 255.255.255.0
And restart the network:
/etc/init.d/networking restart
Apply iptables rules
iptables -A FORWARD -o eth0 -i wlan0 -s 10.0.0.1/24 -m conntrack --ctstate NEW -j ACCEPT iptables -A FORWARD -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
Save the iptables rules
iptables-save > /etc/network/iptables.rules
Create the WiFi hotspot
hostapd /etc/hostapd/hostapd.conf
You're done!
Best regards
Julian
My forum topics:
• Create a WiFi hotspot on Debian 8
• Turn your Pine64 into a music server with mpd
• Adjust brightness of LCD on Armbian Desktop with 1 click
• My cases for Pine64 (acryl, lego & wood)
• Pine 64 - DACH - Facebook page for german-speaking Pine64-fans.
Works fine on Rock64
I have to set up a web server on the SBC so that when it runs , it creates a hotspot around it and the client phones or tablets can connect to access the web-resources present on the webserver.
I am a newbie, please guide me how can i set it up?
I will be using this setup in the environment with no internet connectivity.
Help me out by guiding me to the right direction.
Thank you
Hi waqasnasir,
just create the hotspot as explained and install your favourite webserver.
Change ip-address of the webserver to your local network (like 192.168.0.1) and that's it - nothing special.
There is a ton of tutorials for installing a webserver Smile
Best regards
Julian
My forum topics:
(02-13-2019, 11:37 AM)JulianM Wrote: Hi waqasnasir,
Best regards
Julian
Hi Julian,
Glad to "see" you again :-)
... TL
I bought ROCK64 USB WIFI 802.11B/G/N (RTL8188EU) form Pine64
but I follow this guide but got errot
Configuration file: /etc/hostapd/hostapd.conf
Line 2: invalid/unknown driver 'nl80211'
1 errors found in configuration file '/etc/hostapd/hostapd.conf'
Failed to set up interface with /etc/hostapd/hostapd.conf
Failed to initialize interface
Which driver should I fill on hostapd.conf
and if I do need a driver, where and how to get it
THANKS
Best regards
Julian
Thank you Julian,
I will try the solution.
My scenarios is however little different. I have to use the setup in the environment where there will be no LAN and no Wifi connection.  So the Rock64 or Rockpro64 will be able to generate an Access point with its own SSID that the other mobile devices can connect to to access the Webserver resources.
The whole setup will run in villages in an offline state ..  Internet will not be there and is not at all required..
At the moment, I have both Rock64 and Rockpro64 with configured web server and running smoothly.  Both can connect to Wifi as well.
I have a portable battery operated Access Point (Seperate hardware) , that can create an SSID and i am able to connect the ROCKs to it and the mobile devices are connected to the same SSID and can access the resources on the Webserver.
I am trying to find a way to get rid of the hardware Access Point and make the setup smaller where the ROCKS can generate their own SSID for the mobile devices to connect to.
That need lead me to your page while i was searching for a software based access point / hotspot solution.
After reading the above details, do you think that the tutorial can work in my scenario, or what you suggest ?  I am just one step away for success in my project ..
Also please mentioned ( as per your knowledge ) whether the software based hotspot or Access point has simultaneous connections limit or not ?  May be in my situation, around 50, 60 mobile devices will try to connect to the SSID at the same time.
The hardware Access Point , theoretically can connect to 256 devices simultanously, but i am not sure about the scenario of software based Hotspot/Access Point.
Thank you ..
Regards
Waqas
  [split] Better WiFi/BT module? moriel5 3 10,638 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,809 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 43,417 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,278 07-30-2020, 04:53 PM
Last Post: S265
Information Howto: Getting Bluetooth (serial console) working on Debian pfeerick 14 48,340 08-19-2019, 04:33 AM
Last Post: Roverius
  Schematics of Wifi/BT module gamelaster 7 16,886 09-11-2018, 02:02 PM
Last Post: gamelaster
  Installing another WiFi module on one of the buses mido2018 1 6,207 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,882 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 10,153 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
Sad wifi direct bj_jung 2 8,540 12-29-2016, 10:26 AM
Last Post: happytuna
