config error installing XML-RPC on longsleep Ubuntu
I've used the xenial-pine64-bspkernel-20160716-1.img to install the longsleep Ubuntu then did the apt-get update and upgrade.
EDIT: I just reformatted my card, put on the brand new xenial-pine64-bspkernel-20161217-1.img, did all the other resize, etc, and got the same results below. I' replacing the output from yesterday with the output from today.
I'm trying to install XML-RPC via
svn co -q https://svn.code.sf.net/p/xmlrpc-c/code/stable /tmp/xmlrpc-c
but when I get to the line:  ./configure
it fails because it is unable to guess the build type.
Has anyone been able to get this to work?  How would I go about checking the URLs in their comment to see if it would recognize this custom build? or how would I specify a build?
I know this might be more of an XML-RPC support issue, but this has worked fine on other stock Ubuntu builds I've done in the past.
Thanks for any support you can offer.
The output message I get is below:
root@pine64:/tmp/xmlrpc-c# ./configure --disable-libwww-client --disable-wininet-client --disable-abyss-server --disable-cgi-server
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets $(MAKE)... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... missing
checking build system type... ./config.guess: unable to guess system type
This script, last modified 2009-12-30, has failed to recognize
the operating system you are using. It is advised that you
download the most up to date version of the config scripts from
  http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
and
  http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
If the version you run (./config.guess) is already up to date, please
send the following data and any information you think might be
pertinent to <config-patches@gnu.org> in order to provide the needed
information to handle your system.
config.guess timestamp = 2009-12-30
uname -m = aarch64
uname -r = 3.10.104-2-pine64-longsleep
uname -s = Linux
uname -v = #113 SMP PREEMPT Thu Dec 15 21:46:07 CET 2016
/usr/bin/uname -p =
/bin/uname -X     =
hostinfo               =
/bin/universe          =
/usr/bin/arch -k       =
/bin/arch              =
/usr/bin/oslevel       =
/usr/convex/getsysinfo =
UNAME_MACHINE = aarch64
UNAME_RELEASE = 3.10.104-2-pine64-longsleep
UNAME_SYSTEM  = Linux
UNAME_VERSION = #113 SMP PREEMPT Thu Dec 15 21:46:07 CET 2016
configure: error: cannot guess build type; you must specify one
This seems to solve it for me:
cd /tmp/xmlrpc-c
mv config.guess config.guess.bak
mv config.sub config.sub.bak
ln /usr/share/misc/config.guess ./config.guess
ln /usr/share/misc/config.sub ./config.sub
Please use code blocks for readability.
Wink
  Installing OS for the first time (newbie) mikeardy 1 6,563 05-01-2022, 03:39 PM
  Ubuntu server 20.04 request phi0x 2 11,007 12-30-2020, 08:02 PM
Last Post: phi0x
  systemd-gpt-auto-generator: failed to dissect: input/output error jeanclaude.magras@gmail.com 0 4,741 12-11-2019, 04:10 PM
Last Post: jeanclaude.magras@gmail.com
  Frustrations with Wifi, VNC, Longsleep, etc. NexusDude 1 6,512 06-05-2019, 11:43 PM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 41,164 03-06-2019, 02:26 PM
  SPI on ubuntu IlyaM 4 14,620 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,228 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,528 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 930,887 01-31-2018, 11:58 AM
Last Post: Luke
  Noob help installing Flash shoult 5 11,835 10-20-2017, 10:52 AM
Last Post: sheeponmeth
