Armbian touch screen isuues
I just installed the latest armbian release  ( the desktop xenial I think). I can't get the touchscreen to work. The touchscreen I have is the one from the kickstarter ( i don't the specs right now). I added the gt9.. to the text file and I still get nothing. Is there another way?
To my knowledge, you need to add the gt9xxf_ts module and enable LCD in uEnv :
pine64_lcd=on
Edit: take a look here and read this
I did do that but still no touch screen.
Well if you did everything correctly and still aren't getting anything on the LCD then do join the IRC (in my sig) - easier to troubleshoot.
The lcd works fine. It's the touch sreen that doesn't work.
(02-17-2017, 02:50 PM)tjnoma99 Wrote: The lcd works fine. It's the touch sreen that doesn't work.
Again; Marcus, Xalius and ayufan are currently in the IRC - they will help you out if you join now.
  A64 Euler FAN Support on Armbian Breacher 0 1,574 09-20-2024, 09:57 AM
Last Post: Breacher
Question PINE64 PA642GB Armbian - no Microphone plug spel 1 6,834 11-09-2022, 01:46 PM
Last Post: pinebug
  Armbian 22.02 Release Announcement TRS-80 0 4,684 02-28-2022, 05:04 PM
Last Post: TRS-80
  Software Updates in Armbian CVBruce 1 6,615 07-10-2020, 09:07 AM
Last Post: martinayotte
  Armbian for Pine64 xalius 22 73,163 05-07-2020, 06:27 PM
Last Post: bratoff
  Armbian enable toucscreen right-click burningkrome 0 4,713 12-03-2018, 03:05 PM
Last Post: burningkrome
  PineA64+ Armbian not boot, black screen and log klode 3 11,602 10-14-2018, 04:02 AM
Last Post: evilbunny
Exclamation Armbian Bionic on Pine A64+ black screen starmagoo 11 29,181 08-06-2018, 12:35 AM
Last Post: starmagoo
  +LTS/SOPINE kivy on armbian with lcd baumbachandrew 0 4,712 05-29-2018, 10:15 PM
Last Post: baumbachandrew
  Install VNC Armbian netpr 1 8,185 08-30-2017, 07:03 PM
Last Post: vinodmenon80
