Ubuntu + Domotricz + ZWave + RFlink
Hi All,
I have a Pine64 with ZWave module, installed domotizc on it.
I installed open zwave for domoticz.
For it to work, it was needed to create a symlink from /dev/ttyACM0 -> /dev/ttyS2 as domoticz expects to find the open zwave module on /dev/ttyACM0
Now I also have a RFlink, which is connected to the serial port.
And guess what, when I remove the device and symlink, then I see the RFlink getting created as /dev/ttyACM0
Same way, if I keep the symlink, and connect the RFlink, in the log of domoticz I see it complaining about the ZWave device not properly reponding.
I.e. when I connect the RFLink, it will come as /dev/ttyACM0 even if there is already such a device (ore a symlink to it)
Any ideas how to solve it?
Eric
Solved it!
Solution was actually quite easy:
From this post I got the impression that Domoticz requires that the Open ZWave USB  hardware MUST be on /dev/ttyACM0.
Turns out: Domoticz accepts ANY /dev/ttyACM* device.
So changed the symlink for the ZWave to /dev/ttyACMZwave
Then suddenly Domoticz saw 2 serial ports, one for the ZWave (/dev/ttyACMZwave), the other (/dev/ACM0) the RFlink was on and working...
  Ubuntu server 20.04 request phi0x 2 11,295 12-30-2020, 08:02 PM
Last Post: phi0x
  SPI on ubuntu IlyaM 4 14,910 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,490 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,912 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 950,406 01-31-2018, 11:58 AM
Last Post: Luke
  PPTP doesnt work with ubuntu escovedo 2 13,741 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Question HELP Ubuntu Mate password recovery procedure Captain Anni Hilator 5 15,651 08-03-2017, 03:52 PM
Last Post: Luke
  Ubuntu boot very slow with wifi driver remainder 9 28,589 08-03-2017, 07:23 AM
Last Post: victorssantos
  Recovering root access in Ubuntu Scientomancer 3 10,473 07-28-2017, 02:53 PM
Last Post: Scientomancer
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 4,667 07-08-2017, 09:34 AM
Last Post: petec
