Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO*
I found using the end up a needle nose pliers the easiest way to assemble the final 4 nuts. Just press firmly down on the handles with one hand and rotate it. I have rubber feet on both sides but you may have to hold the case to stop it from sliding around.
I saw another video that suggests assembling the two screws and shown and then assembling the base pieces together using the two short screws and nuts NEXT. It is a LOT better method. It hold them together and does not interfere with putting on the corner pieces which now go on A LOT easier. I would also assemble one screw to each, not fully tight but close, before adding the screen. The avoids you having to fight gravity since they are already in place and you can assemble it with screen upward and make any adjustments with ease.
I would like to see a "tall" version too so I could either mount a fan internally or use the Z-Wave or similar module, etc.
http://c4labs.net/products/screen-case-for-pine-64
http://c4labs.net/products/zebra-black-i...-tall-case
Link the video.
    I ordered one of these and see that with some small modifications, it can be turned into a very sleek, standing case.
I'm dropping the corner brackets, which are only needed to protect the screen if the unit is used as a playbox. Mine will be standing permanently in my HiFi shelves in picture-frame posture.
That brings me to my question or request.
If anyone knows of a source of some flat aluminium brackets, about 3mm thick, 1-2cm wide and bent at a 65°/115° angle, that could be cut to length and polished, I'd be happy to know about them. I don't care what they're originally intended for.  One end will be bolted to sides of the back of the C4 enclosure, while the other will sit on the shelf, supporting the unit at a nice, 65°(ish) angle.
Of course I can manufacture them myself if necessary, but bending two, exactly matched angles from flat aluminium may be difficult.
Cheers!
--Marius--
Photo C4 Labs Pine 64 Cases (Standard & LCD) Bluphire 95 237,581 11-02-2020, 08:43 PM
Last Post: Little_Johnny
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 97,688 07-23-2020, 05:31 AM
Last Post: devendraraju
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,227 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 50,965 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,336 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 12,667 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,764 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 20,938 02-07-2017, 08:45 PM
Last Post: Bluphire
  Tablet Enclosure Vachtra 11 31,160 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 28,242 11-01-2016, 06:23 PM
