config error installing XML-RPC on longsleep Ubuntu
I've used the xenial-pine64-bspkernel-20160716-1.img to install the longsleep Ubuntu then did the apt-get update and upgrade.
EDIT: I just reformatted my card, put on the brand new xenial-pine64-bspkernel-20161217-1.img, did all the other resize, etc, and got the same results below. I' replacing the output from yesterday with the output from today.
I'm trying to install XML-RPC via
svn co -q https://svn.code.sf.net/p/xmlrpc-c/code/stable /tmp/xmlrpc-c
but when I get to the line:  ./configure
it fails because it is unable to guess the build type.
Has anyone been able to get this to work?  How would I go about checking the URLs in their comment to see if it would recognize this custom build? or how would I specify a build?
I know this might be more of an XML-RPC support issue, but this has worked fine on other stock Ubuntu builds I've done in the past.
Thanks for any support you can offer.
The output message I get is below: root@pine64:/tmp/xmlrpc-c# ./configure --disable-libwww-client --disable-wininet-client --disable-abyss-server --disable-cgi-server checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking whether make sets $(MAKE)... yes checking for working aclocal... found checking for working autoconf... found checking for working automake... found checking for working autoheader... found checking for working makeinfo... missing checking build system type... ./config.guess: unable to guess system type This script, last modified 2009-12-30, has failed to recognize the operating system you are using. It is advised that you download the most up to date version of the config scripts from http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD and http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD If the version you run (./config.guess) is already up to date, please send the following data and any information you think might be pertinent to <config-patches@gnu.org> in order to provide the needed information to handle your system. config.guess timestamp = 2009-12-30 uname -m = aarch64 uname -r = 3.10.104-2-pine64-longsleep uname -s = Linux uname -v = #113 SMP PREEMPT Thu Dec 15 21:46:07 CET 2016 /usr/bin/uname -p = /bin/uname -X = hostinfo = /bin/universe = /usr/bin/arch -k = /bin/arch = /usr/bin/oslevel = /usr/convex/getsysinfo = UNAME_MACHINE = aarch64 UNAME_RELEASE = 3.10.104-2-pine64-longsleep UNAME_SYSTEM = Linux UNAME_VERSION = #113 SMP PREEMPT Thu Dec 15 21:46:07 CET 2016 configure: error: cannot guess build type; you must specify one root@pine64:/tmp/xmlrpc-c#
This seems to solve it for me:
cd /tmp/xmlrpc-c mv config.guess config.guess.bak mv config.sub config.sub.bak ln /usr/share/misc/config.guess ./config.guess ln /usr/share/misc/config.sub ./config.sub
Please use code blocks for readability.
Wink
  Installing OS for the first time (newbie) mikeardy 1 6,794 05-01-2022, 03:39 PM
  Ubuntu server 20.04 request phi0x 2 11,309 12-30-2020, 08:02 PM
Last Post: phi0x
  systemd-gpt-auto-generator: failed to dissect: input/output error jeanclaude.magras@gmail.com 0 4,871 12-11-2019, 04:10 PM
Last Post: jeanclaude.magras@gmail.com
  Frustrations with Wifi, VNC, Longsleep, etc. NexusDude 1 6,703 06-05-2019, 11:43 PM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 42,027 03-06-2019, 02:26 PM
  SPI on ubuntu IlyaM 4 14,926 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,500 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,921 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 951,010 01-31-2018, 11:58 AM
Last Post: Luke
  Noob help installing Flash shoult 5 12,087 10-20-2017, 10:52 AM
Last Post: sheeponmeth
