anyone make pine64 lcd hdmi work simultaneously
has anyone make pine64 lcd hdmi work  simultaneously? lcd hdmi work at the same time
(11-17-2016, 01:44 AM)bokeer Wrote: has anyone make pine64 lcd hdmi work  simultaneously? lcd hdmi work at the same time
Power it up without the HMDI plugged in then insert the HDMI cable. Works in Android.
http://forum.pine64.org/showthread.php?t...5#pid15055
As stated in the above forum post:
Actually the 20160603 build of Android with LCD support ( http://wiki.pine64.org/index.php/Pine_A6...e_20160603 ) supports using both HDMI and LCD at the same time. It is a cloned image and not sure if able to set up to use as a multiview or continual screen. I know this is working as I use it to play pokemon red on a hdtv through HDMI cables and it also shows on my LCD at the same time. Kinda overkill but cool none the less.
(11-17-2016, 01:56 PM)jjmgryphon Wrote: http://forum.pine64.org/showthread.php?t...5#pid15055
I just tried this and I was unable to connect to my tv via hdmi. Is their something I need to turn on? I know you have to go and edit some files in order to get the sound to go through hdmi, do you need to do something similar to activate the hdmi?
Did you get the LCD image ?  Also, you may want to consider giving ayufan's build a go.
  Pine64+ 1G and Pine LCD with Android 6.0.1 Tanveer 0 8,523 09-03-2018, 05:05 AM
Last Post: Tanveer
  HDMI CEC on Android fneves 39 84,705 03-10-2018, 06:08 PM
Last Post: lupa18
  Possible to simultaneously connect to ethernet & wi-fi? wahdooyah 3 7,870 01-26-2018, 06:57 PM
Last Post: dkryder
  2nd ethernet in PINE64 with android daniele 2 7,180 12-07-2017, 05:09 AM
Last Post: daniele
  USB Mic + HDMI Speaker jack_shepherd 0 3,328 11-27-2017, 03:27 AM
Last Post: jack_shepherd
  Pine64 + Youtube TV Performance mikedice417 0 3,716 11-25-2017, 10:36 AM
Last Post: mikedice417
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 7,624 11-16-2017, 02:14 PM
Last Post: Skivholme
  Android 7.1 reboot on Pine64 2GB rkbren81@gmail.com 2 7,062 11-07-2017, 06:33 AM
Last Post: rkbren81@gmail.com
  Connecting external DVDRW drive via USB to Pine64 galbez 4 10,769 10-12-2017, 12:35 PM
Last Post: Luke
  Does snapchat work on pine64 with android? user875545 1 7,038 08-29-2017, 12:05 AM
