Pine A64 + OpenHAB + Sonoff-pow: Would it Work?
Pine has the Linux version of OpenHAB 2.0 functioning now.
Would it work to control these device controls?  They are which are $10.50 per outlet and connect by wifi.
https://www.itead.cc/sonoff-pow.html
Interested in your thoughts on this.
(11-03-2016, 01:06 PM)Bob123456789 Wrote: Pine has the Linux version of OpenHAB 2.0 functioning now.
I recently bought a couple sonoff devices and I am hoping to try it out this weekend.  From what I've seen for youtube on openHab it should work when adding as a thing in openhab.
Chadilac, I'll be anxiously waiting on your results (and anyone else's that wants to give it a try and report back here).
Inside the Sonoff is an ESP8266. In particular I am interested in if you end up having to reprogram the flash memory in the ESP8266 to get it up and running like this guy did:
http://www.superhouse.tv/17-home-automat...-and-mqtt/
It is a great example. His hardware is based around the Sonoff, Openhab and an Arduino. His code is there as are the steps to reprogram the flash memory.
The cool thing is that the ESP8266 can be set up to work remotely over wifi with no control board (Arduino, pine, raspberry,...). And they are very inexpensive and readily available. They can be set up to control relays, as temperature sensors,... I could see them working well with Openhab on a Pine.
I have actually gotten the Sonoff Basic working with OpenHAB on a Pine64. I had to work through the entire process multiple times, but finally figured at all the bits and bobs to get it to work.
The problem I had was there was not any one location with all the information in one place.
I have documented the process and I will soon be putting a series of post on my blog and videos. My goal is to explain each piece as I go. OpenHAB is great, but it is capable of so much that ,if you are just starting into DIY home automation, it makes it hard to get started with it.
Until I get my content up, I will attempt to answer any questions I can here.
FYI - I just ordered 3 SonOff Basics for less than $20 shipping included. My source below.
http://www.banggood.com/DIY-Wi-Fi-Wirele...7222016031
Frank Wolfe
Wannabe Maker - making mistakes so you don't have too!
Sonoff and openHAB work perfectly together. Check out this full tutorial:
https://community.openhab.org/t/itead-so...ware/15024
Great news Frank!
It looked like it should be possible and would be a great inexpensive solution.
Have you had a chance to write up the steps yet? We all can't wait to see how you implemented things.
What are you controlling using them?
wvwolfie. Would you be able to share how you got it working?
  openHAB Packaging for the Pine64 kai 19 50,812 02-21-2017, 07:19 AM
Last Post: BatoXan
  Keeping Openhab current socken23 4 12,943 01-13-2017, 12:51 AM
Last Post: swinging
  OpenHAB And Zwave FrenchFrog 12 34,382 09-13-2016, 11:17 PM
Last Post: bonterra
  OpenHAB Up - Getting My Bearings - Questions doundounba 4 12,305 07-08-2016, 12:38 AM
Last Post: av1024
Information [solved] Openhab not starting socken23 10 25,104 06-21-2016, 12:50 PM
Last Post: Luke
  openHAB just up on Pine64 :-) tllim 2 11,274 05-04-2016, 05:27 AM
Last Post: Luke
