3,5mm audio out not working
I don't seem to be getting audio from 3,5mm jack working. I have tried ayufan's Android 5.1 and 7.0 builds (TV and no TV), to no luck whatsoever. Also tried plugging the jack only after a reboot, but still nothing. Sound comes only through HDMI.
Can anybody help? Or confirm that it really doesn't work? From what I read, this has been an issue before, but some reports at least from the Linux side are saying it shold work.
Mikko
Interesting. I tested Audio jack and it worked.
Can you show you ADB logs?
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
My audio jack is also working. Can you try a different headset/plug please.
As the detection is done by an electrical connection being made from the headphone plug.
Backer #6878
shipment status: arrived
On page 8 of 19 ( schematic ) the audio plug is a four connector plug < L, R, Grnd, Mic ]] ;  Samsung earbuds work well ( with the in-line mic pick-up );  there are others that will work as well as long as they are standard sterioe buds with monoral mic puckup.
Make sure the plug is the standard four connector plug and that it is fully seated.
(09-28-2016, 11:53 PM)MarkHaysHarris777 Wrote: On page 8 of 19 ( schematic ) the audio plug is a four connector plug < L, R, Grnd, Mic ]] ;  Samsung earbuds work well ( with the in-line mic pick-up );  there are others that will work as well as long as they are standard stereo buds with monoral mic puckup.
Tried a couple different cords that work with my Minix X8H+ ... no sound, just static humming.
Got things finally working with the SoundAbout app by forcing audio routing to wired headset.
I had to use the SoundAbout on mine as well. Occasionally I can unplug and replug in the 3.5mm jack and get it to realize it's there but that is not consistent. I'm not sure if it is the switch/sensor in the 3.5mm jack that doesn't know to check for state when started or refreshed or if it is a software issue that it is setting default for audio to another point (my guess is the gpio) as standard audio on cell phones doesn't go to the 3.5 jack unless something is plugged into them. Atleast there is a easy work around at the moment for android.
I'm running the Debian Stretch OS and cannot get the audio from the headphone jack. It works fine through the HDMI in my television. Numerous attempts with external speakers and earbuds proves fruitless. Since there is no onboard BT, I need to hook up external speakers when using a monitor.  I was looking for the selector present on my RPi3 changing from input sources.
Writing this with audio playing thru TV.
Help???
(03-10-2018, 06:45 AM)le_moose1 Wrote: I'm running the Debian Stretch OS and cannot get the audio from the headphone jack. It works fine through the HDMI in my television. Numerous attempts with external speakers and earbuds proves fruitless. Since there is no onboard BT, I need to hook up external speakers when using a monitor.  I was looking for the selector present on my RPi3 changing from input sources.
Help???
You need to create a asound file...
https://forum.pine64.org/showthread.php?tid=5698
Perhaps it's not the good place because i use a Rock64 sbc, but as i had the same issue, i searched for a solution and found these useful links:
https://stackoverflow.com/questions/5972...u-manually
https://ubuntuforums.org/archive/index.p...70383.html
regards
my pine64 LTS seems to be only getting sound out of 1 side with a headset
  MTP Stopped Working miller08 0 4,895 12-24-2019, 02:42 AM
Last Post: miller08
  Android audio Danbrack 0 3,600 03-24-2018, 10:51 PM
Last Post: Danbrack
  Wiki version of Android 7.1 not working with touchscreen abba2566 3 8,903 02-28-2018, 08:02 AM
Last Post: wezzjm
  <•••> and no audio on my android is Help PoppaLeague 0 3,344 09-10-2017, 01:32 AM
Last Post: PoppaLeague
  Microphone / Audio In iammackinnon 4 10,353 04-24-2017, 07:03 AM
Last Post: kenjiru
  Android 6.0 TV analog audio Ophir 2 7,848 02-02-2017, 03:55 PM
Last Post: Ophir
  HDMI not working gubaguba 7 14,537 01-25-2017, 09:45 PM
Last Post: MakerLing81
Information Audio Passthrough in SPMC Working czechr08 8 27,783 11-02-2016, 06:54 PM
Last Post: czechr08
  Netflix and Twitter no longer working Punkyclown 0 3,859 10-20-2016, 08:45 AM
Last Post: Punkyclown
  USB Audio? mesaxi 3 7,567 09-28-2016, 09:45 PM
Last Post: mikey0000
