Creating a phone with the Pine64 and need a bit of help
I plan to create a phone with the Pine64 is there anyway I can support a sim card in this build as i really want to give this the full capability of a phone and more features if anybody can give me a idea on how to that will be a great help thanks Smile
it would be very difficult to make a traditional cellphone type of phone with the pine64, you would have to integrate all the necessary hardware and supporting software. i'd suggest using one of the android images that supports hangouts[if any do, i'm not sure if in fact hangouts does work] and use a google number to do pretty much near what you want if that would be phone like communication via the pine64
You could use a cellular module and create a UI for it with your Pine, like https://www.sparkfun.com/products/13120 for example...
(09-24-2016, 07:12 AM)xalius Wrote: You could use a cellular module and create a UI for it with your Pine, like https://www.sparkfun.com/products/13120 for example...
yes. or particle.io has the electron. but the electron probably won't do calls on their network. but either would lack the integration needed to have a "phone" , if the OP does want a traditional type cellphone concept. perhaps search   hackster.io   for some ideas.
(09-24-2016, 12:21 AM)dkryder Wrote: it would be very difficult to make a traditional cellphone type of phone with the pine64, you would have to integrate all the necessary hardware and supporting software. i'd suggest using one of the android images that supports hangouts[if any do, i'm not sure if in fact hangouts does work] and use a google number to do pretty much near what you want if that would be phone like communication via the pine64
Hangouts is supported on the Android images, we're using it now and it works well.
Sent from my PINE A64 using Tapatalk
  Pine64 as squeezebox touch replacement Learnincurve 12 42,660 01-13-2021, 02:11 AM
Last Post: Learnincurve
  Pine64 E-ink screen - Android projectileobjects 4 14,472 12-03-2020, 03:03 PM
Last Post: Silk
  Pine64 based IP KVM tuaris 0 6,682 08-06-2020, 12:05 AM
Last Post: tuaris
Information Pine64 Head Unit Zoidiano0 100 224,944 11-19-2019, 04:35 AM
Last Post: rogatip79
  PINE64 to allow use of SATA disk on network/FTP mwelbourne 10 26,572 11-18-2019, 04:09 PM
Last Post: evilbunny
  How to setup VNC on your Pine64 (Debian, SSH, headless) pine64nutz 20 62,609 04-16-2019, 08:00 AM
Last Post: hg6806
  Setup Pine64+ with OP-TEE stdys 0 6,057 09-13-2018, 03:23 PM
Last Post: stdys
Information UEFI for Pine64 z4v4l 20 63,184 06-24-2018, 03:06 PM
Last Post: z4v4l
  Domoticz + PINE64 Z-Wave Module + Open Z-Wave klliew 4 15,106 04-19-2018, 02:23 AM
Last Post: Harlan Mueller
  Pine64 as Security Camera / Baby Monitor utdrmac 2 11,108 02-01-2018, 07:49 AM
Last Post: davidbrucs
