Tor on debian
It works?
https://www.torproject.org/docs/debian.html.en
Can't see why not. Use an external WiFi adaptor and follow instructions out there for a tor access point.
Use internal WiFi to connect to your network and then have it broadcast your tor WiFi using hostap and like an atheros or compatible USB adaptor. I have successfully used ralink chipsets in the past.
I built one on RPI about a year ago.
But that's just one use. If you can get tor to compile and all networking side of things to play nice, you should be able to setup an exit node or a hidden service.
Edit: I found information that should be able to be adapted for the pine64.
http://makezine.com/projects/browse-anon...or-router/
Sent from my HUAWEI RIO-L02 using Tapatalk
  Debian installer on Pine A64+ but no hdmi mrwick 1 9,082 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,495 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,519 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 16,833 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 166,114 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,418 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,760 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 11,035 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 21,149 03-29-2019, 02:00 AM
Last Post: desai_amogh
  (ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 259 673,479 05-21-2018, 06:30 AM
Last Post: Luke
