White box plastic enclosure
Today I received the Pine 64 enclosure, a white plastic box.
However, it was closed up. The lid is held by six hooks to the case
on the inside and you cannot lift the lid from the case,
so it is not posiible to put the Pine 64 board inside.
can somebody help?
hi, reach inside and unsnap the tabs; pull the two halves apart.
... before snapping it back together with the pine inside, use a dremel tool and carefully drill a small paper clip sized hole in the enclosure where each tab will be... then to reopen the enclosure, press an unfolderd paper clip into the hole to release each tab.
Is this ideal?  Of course not.  The enclosure has several very irritating design flaws that we are having to live with... this is just one of them.  If you have further questions, please visit us on irc chat and we'll help you.
Never mind getting the lid off, what about getting the lid on with the z-wave module attached, the antenna of which protrudes above the top edge of the case? Any ideas - drill more holes?
See this thread for your solution to the PlayBox:
http://forum.pine64.org/showthread.php?tid=2277
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,519 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 51,324 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,438 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 12,811 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,846 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,107 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 38,905 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 31,389 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 28,498 11-01-2016, 06:23 PM
Rainbow DMG/Classic Gameboy Enclosure!? n_n' Gearsoul 54 104,945 09-16-2016, 12:21 PM
Last Post: Ghost
