ABS Playbox came with no extension cable?
I have seen some videos on assembling the Pine64 with the playbox and they all mention at lest one extension cable. My case just arrived with none and so I have 2 questions;
1. Anyone know the 30 pin cable type and/or where to order it from?
2. Is it worth trying to chase it down through pine64?
Now before the flames start let me just say I am in no way attacking these guys for the work they've done with the last question. I'm more wondering about response times and it would probably be easier to order a cable from somewhere else.
All that aside I am still anxious to see if this project works because I've waited (patiently) for all the pieces to come before I set it up.
thanks in advance.
I was going to get it from here http://www.ebay.com/itm/151985309073?_tr...EBIDX%3AIT but turns out I don't need it.
(09-07-2016, 02:24 PM)kenhawkins Wrote: I have seen some videos on assembling the Pine64 with the playbox and they all mention at lest one extension cable. My case just arrived with none and so I have 2 questions;
thanks in advance.
The extension cable (and adapter) is in the bottom of the LCD display box where it is very easily missed; and often discarded with the packaging.  You might check yours, if you still have it.  The cable and connector are fairly common parts, is the good news;  just google it.
thanks in advance.
I did look in there but alas it's not there. thanks.
thanks in advance.
Same here.  Got the short one with the LCD, but didn't get one with the case.  Ordered some, but will be here Friday-next week.
  Playbox with DAC llungster 0 5,019 04-02-2019, 09:02 AM
Last Post: llungster
  playbox case ribbon cable too short pinoosh 7 20,213 02-22-2019, 03:24 AM
Last Post: GaryFunk
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 17,080 07-16-2017, 01:51 AM
Last Post: selina3
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,548 06-17-2017, 01:29 AM
Last Post: pfeerick
  playbox and camera jpfaubert 1 6,669 03-07-2017, 12:51 AM
Last Post: MarkHaysHarris777
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,943 02-12-2017, 10:17 PM
  Playbox battery charge jdmwrx94 12 30,558 12-20-2016, 07:19 AM
Last Post: Toriless
  Playbox case orderable? schindlb 8 21,956 10-02-2016, 08:20 AM
Last Post: schindlb
  Solution to awkward playbox cabling Visionrx7 2 7,214 09-13-2016, 11:46 PM
Last Post: Visionrx7
  Question regarding Playbox case jeffrey_ring 3 8,724 09-13-2016, 07:39 PM
