LCD screen with android, runs fine, screen does not turn back on..?
I was having problems getting the 7" touch screen to work and found out it was the image I was using. So I went and downloaded phoenix card and the image from pine 64 "lcd-version-20160419" and after the first few boots, it works great. Everything is running smooth even though strangely enough phoenix card failed to burn the image about 3 times and on the 4th time, it worked. Well now the problem is that if I let the screen turn off on its own or I hit the little power button I have on the board and leave it for a few seconds, I can't get the screen to turn back on unless I reset the whole unit with the reset button. They are both the buttons you can get from pine64 for like 50 cents each. I don't think it is a poor connection since the buttons work fine unless the screen is off and then it seems like the power button is completely unresponsive. Anyone else having this problem? I just got the playbox case and also have the (official pine64) battery installed.
hi, the difficulty your are experiencing is normal for this unit. In my personal opinion this is a design flaw which most of us have experienced by now.
... the power button short press suspends the pine board (unfortunately also will not awaken it most times once suspended; requires reset or removing power )
The power button long press will bring up the power off dialogue ; the power on button may then be used to power the device back ON.
Try to avoid the power button short press.  Remember to press and 'hold'.
(09-01-2016, 12:22 AM)MarkHaysHarris777 Wrote: hi, the difficulty your are experiencing is normal for this unit. In my personal opinion this is a design flaw which most of us have experienced by now.
Alright, sounds good! Thank you for such a quick reply.
  7" LCD Touch Screen Panel IanJames 0 3,484 04-01-2020, 04:40 PM
Last Post: IanJames
  User Screen Black After Changing Power Settings 0b51Gekko 2 7,992 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
Question Do I need a touchscreen to run Android? chrbar 3 8,500 08-08-2018, 10:55 PM
Last Post: chrbar
  ethernet lan speed problem android fulltone 0 3,996 04-23-2018, 01:47 AM
Last Post: fulltone
  Rock64 + 7" touch screen naviathan 2 7,497 09-28-2017, 09:01 AM
Last Post: naviathan
  No sound on Android 6 or 7.1 reeno 0 4,277 07-29-2017, 06:31 PM
Last Post: reeno
  7" Screen - Does it work with Debian abasel 1 6,143 07-26-2017, 05:44 AM
Last Post: pfeerick
  Boots just fine. Can not install new image. willpine 5 12,100 07-25-2017, 06:39 AM
Last Post: willpine
  RESOLVED - LCD screen not working, HDMI does asuras 10 24,258 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI-VGA adapter. Blank screen. trumad 10 27,527 03-05-2017, 03:17 AM
Last Post: pfeerick
