How to install Gentoo on Pine64 ?
I would like to know if there is any specific instruction on how to install Gentoo or Linux From Scratch on Pine64.
For raspberry pi I used to install raspbian and copy the firmware and kenrel files to my Gentoo installation.
I just wanted to know if there is any specific "setting" required in order to run a linux distribution on Pine64 or some firmware blobs and where I could find those.
Thank you very much in advance!
(05-29-2016, 08:20 AM)ilovegentoo Wrote: Hi,
I use Gentoo also, but I don't have my pine64 yet. I did basically the same thing on my raspberry pi - use the kernel and firmware that they provide and attach it to gentoo's stage3.
For the pine64, I would start with one of Longlseep's debian or ubuntu images. Keep the boot partition, and copy everything from /lib/firmware and /lib/modules into your Gentoo root.
There's an "experimental" stage3 for arm64 at http://distfiles.gentoo.org/experimental/arm64/ - it hasn't been updated in a little while but I was able to work with just fine the other day in a chroot environment.
I used the experimental stage3 tarball with one of longsleep's Ubuntu images and installed the system from an Ubuntu system running on my Pine (Gentoo card was in a USB cardreader). If you follow the normal steps from the Gentoo installation manual it just works... just leave out the partitioning and kernel / bootloader steps, dont forget to install the kernel modules as well and a sshd... after that I just built some necessary packages to get the platform scripts up and running... I can upload the image once I cleaned it up a little if people want to play with that...
Xalius, thank you.
... I have been testing one of Xalius' Gentoo images today; very nice work dude ! The Gentoo distro (with the longsleep kernel and newly integrated drm code) has corrected the frame buffer console cursor error (its been missing for a while). All subsequent kernel(s) should have this new fix shortly.
The Gentoo image is lean, mean, and clean ! I have not used Gentoo before now, but am finding this build to have what is expected; it is solid, stable, and a lot of fun too.
Again, Xalius thank you ! ( a very positive contribution )
  Programming languages support under PINE64 baryluk 6 20,573 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,594 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 38,963 03-22-2019, 09:25 AM
Last Post: llungster
  Gentoo Linux test image xalius 23 72,916 01-28-2019, 11:05 PM
Last Post: necrose99
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,629 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,069 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 56,791 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,962 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,502 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,659 12-09-2017, 08:14 AM
Last Post: incoherent
