Keeping Openhab current
Hi all
Since the current image comes with the Beta version, does anyone know how to keep the installation up to date?
How can I install the latest nightly builds?
It seems that there are different ways of achieving this that depend on how you installed openhab.
So I guess the question is also, how was openhab installed on the official image? Manually? Via apt?
This image predates the debian images, so it was installed manually and registered as a system service like described here: http://docs.openhab.org/installation/ind...spberry-pi
So you can simply delete the existing installation and either unzip a snapshot version in the same location or switch to the apt installation.
(07-25-2016, 02:49 AM)kai Wrote: This image predates the debian images, so it was installed manually and registered as a system service like described here: http://docs.openhab.org/installation/ind...spberry-pi
Great, thanks a lot for the details. I'll probably switch to the apt installation then.
Stopped openhab, moved the folder /opt/openhab and installed with apt again. Worked like a charm. Thanks again!
  Pine A64 + OpenHAB + Sonoff-pow: Would it Work? Bob123456789 6 16,254 05-31-2017, 02:54 PM
Last Post: Bob123456789
  openHAB Packaging for the Pine64 kai 19 48,207 02-21-2017, 07:19 AM
Last Post: BatoXan
  OpenHAB And Zwave FrenchFrog 12 32,687 09-13-2016, 11:17 PM
Last Post: bonterra
  OpenHAB Up - Getting My Bearings - Questions doundounba 4 11,514 07-08-2016, 12:38 AM
Last Post: av1024
Information [solved] Openhab not starting socken23 10 23,477 06-21-2016, 12:50 PM
Last Post: Luke
  openHAB just up on Pine64 :-) tllim 2 10,747 05-04-2016, 05:27 AM
Last Post: Luke
