Ubuntu 16.04 and Zoneminder
I have been able to use a pine64 2GB to install zoneminder 1.29 and it is running just fine.  It replaces a monstrous old PC that had been converted to linux.
(07-23-2016, 02:01 PM)ewtaylo Wrote: I have been able to use a pine64 2GB to install zoneminder 1.29 and it is running just fine.  It replaces a monstrous old PC that had been converted to linux.
Glad to know that Zoneminder now works with Pine64. If possible, please provide the installation process and other Pine64 forum users can follow.
Hi.
I did install it as well. Standard install procedure found for Ubuntu if installed from official repos.
Not a single glitch nor did I have to wander off the procedure's "path".
Working fine now.
Best regards.
Marc "Duke Justice" Arbour
See my Pine64+ 2GB Poor Man's Heatsink Setup
Fellow Zoneminder user!
One week into Pine and have also migrated my previous old Zoneminder server over. For the most part the published "Install Zoneminder on Ubuntu - the easy way" instructions worked well. Over the years, have installed Zoneminder about 6 times on Centos, Ubuntu, physical and VM systems, and never had one go 100% without a annoying issue ot two. Always get it working in the end. A good challenge on one in the past was getting the server to email alerts using a Gmail account because the local ISP blocked port 25.
My new build on Pine uses an external 1TB drive for the video files. Had to modify the symboloic links at /usr/share/zoneminder/www to pint to the external drive. Also had to disable Auth_relay in the Zoneminder Gui settings to get live video feeds working. This glitch only showed up after enabling username authentication. And of course there was the documented ZM-CGI path edit that needed to be changed.
All good so far. Only 3 cameras for now, but CPU is under 13%, and the system is also serviving up cloud content via Owncloud.
W.
  Ubuntu server 20.04 request phi0x 2 11,309 12-30-2020, 08:02 PM
Last Post: phi0x
  SPI on ubuntu IlyaM 4 14,922 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,494 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,919 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 951,005 01-31-2018, 11:58 AM
Last Post: Luke
  PPTP doesnt work with ubuntu escovedo 2 13,762 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Question HELP Ubuntu Mate password recovery procedure Captain Anni Hilator 5 15,657 08-03-2017, 03:52 PM
Last Post: Luke
  Ubuntu boot very slow with wifi driver remainder 9 28,594 08-03-2017, 07:23 AM
Last Post: victorssantos
  Recovering root access in Ubuntu Scientomancer 3 10,479 07-28-2017, 02:53 PM
Last Post: Scientomancer
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 4,670 07-08-2017, 09:34 AM
Last Post: petec
