It's the sd card!
Hi there,
After some trouble and after buying hipo USB chargers etc, it turns out that it was the sd card!  A Kingston 32gb card wouldn't boot past the first screen.  A Sandisk 16gb runs like a boss!  I tried various burns, power supplies etc and none of them mattered.  It was the sd card.  I've got two pines so now I'll try a sandisk 32gb for the second one.
My pine is running fine via a ue boom usb charger and the flat yellow cable that came with it.  I burned remix using phoenix and my laptop.
Good luck!  I figured I should let people know what worked for me.  Someone needs to work up a list of sd cards that work.  Add the cheapest (in australia) Sandisk 16gb.  It's at least a 10x one, but seriously the cheapest.
cheers john
Oh and the wifi module just plugs in and works. So did my logitech usb thing - plugged it in when I got to the first option screen on first boot and it instantly worked. Good stuff!
I strongly recommend the Samsung 32Gb Evo+ Class 10 cards.
marcushh777
(07-18-2016, 04:00 AM)MarkHaysHarris777 Wrote: I strongly recommend the Samsung 32Gb Evo+ Class 10 cards.
marcushh777
hear hear Marcus Smile
Perhaps a counterfeit SD card? See tkaiser's thread here
marcushh777
Cheers. My local was out of them. Got one on order :-)
  How to boot from SD card on pinebook pro linux123 3 10,457 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 7,196 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,262 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 10,409 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 303,998 03-03-2020, 11:34 PM
Last Post: siyatalerja
  eMMC card on adapter Malmgren 8 19,069 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 16,266 02-08-2017, 05:42 PM
Last Post: maxpayne
  recommended micro sd card? Gustavo Woltmann 1 6,196 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 6,174 11-03-2016, 02:33 PM
  SD card burn img size problems stephen0205 17 38,132 09-22-2016, 06:28 AM
Last Post: tkaiser
