Kodi on Android
#71
(07-07-2016, 08:51 AM)pinea64.edison Wrote:
(07-07-2016, 07:38 AM)gorzany Wrote:
(07-07-2016, 06:40 AM)gbjensen Wrote:
(07-07-2016, 05:14 AM)pinea64.edison Wrote: Pine64 does not support CEC and so your TV remote will not work... For context menu try long pressing the left mouse key and see if that works.
Sent from my Nexus 5 using Tapatalk
You can download a remote app to you android phone (if you have one) and control Kodi this was as well.
One example is the app Yatse.  you will need to configure Kodi to enable the remote control.
Yatse only works on KODI but not on android... so you still need additional remote.
I don't know if it works flawlessly, but there is an IR pine64 remote on the shop.
I wonder if similar IR remotes for android TV can work with pine64.... anyone tried that so far?
I actually got an Air mouse remote from Amazon and it seems to work well...I am able to use it even for some basic games as well as Kodi.
thanks, it's encouraging... i could not find a simple and appropriate remote IR app to control the pine through my smartphone. so a dedicated remote (with implemented keyboard) is the way to go.. Cool
#72
This is the one i got from Amazon...
https://www.amazon.com/Ideapro-Wireless-...=air+mouse
#73
(07-07-2016, 06:40 AM)gbjensen Wrote: You can download a remote app to you android phone (if you have one) and control Kodi this was as well.
I use this remote too, its an excellent remote for the price
#74
Well I just bought a Logitech K400 Plus wireless model.
Will this work with Android and Remix OS? What about Ubuntu andArchLinux?
I also got 2x units of 16GB Samsung EVO to install Linux and possibly Android\Remix.
I hope this will work fine.
#75
(07-14-2016, 04:20 AM)vinodmenon80 Wrote: Well I just bought a Logitech K400 Plus wireless model.
I have the same keyboard and it works perfect, on remix os first make sure it is unplugged as it doesnt seem to be boot with usb plugged in.
#76
(07-14-2016, 03:19 AM)anarchyuk Wrote: This is the one i got from Amazon...
If anyone doesn't mind the long wait, this looks like the exact same mouse sold at Amazon for $6 less.
#77
anyone having kodi sound issues. When there is silence in a video, on youtube or netflix, its like it turns the audio source off for a second.
when i start a video it will miss like the first second or 2 then the audio will cut in, but it also does it with pure silence, and then cuts back in.
Any idea how to fix
#78
(08-20-2016, 02:27 AM)stephen0205 Wrote: anyone having kodi sound issues. When there is silence in a video, on youtube or netflix, its like it turns the audio source off for a second.
Any idea how to fix
I have the same problem.
I tried with different kodi versions and settings . Undecided
#79
Did you try SPMC? If not, give it a try.
#80
(08-25-2016, 03:50 PM)pinea64.edison Wrote: Did you try SPMC? If not, give it a try.
Yes I did, and passthrough is giving me just a noise.  Sad
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,921 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 616,107 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,945 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,523 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,916 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,568 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,792 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,900 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 415,030 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,702 02-26-2019, 11:58 AM
Last Post: Twistedx
