RTC Backup Battery - CR
I didn't get a good second look at it. Is there a connector attached to the wires or will I need to attach one? Thanks
(02-18-2016, 08:50 AM)sbentjies Wrote: I didn't get a good second look at it. Is there a connector attached to the wires or will I need to attach one? Thanks
Connector will be attached. Please see this thread:
http://forum.pine64.org/showthread.php?t...47#pid2447
Can someone recommend a particular PINE A64 RTC-compatible battery, with the proper 2-pin connector, sourced from Amazon, or another reputable online electronics parts store?
regards,
J. Ouellette
    A64-DB-2G-RevB (2016-03-21)
    +WiFi/BT +IR
    Android Lollipop
    Ubuntu/Xenial 16.04LTS/3.10.102-2-pine64-longsleep (64GB)
    Debian 8.5 (jessie)/MATE 1.8.1/3.10.102-2-pine64-longsleep (64GB)
adafruit has several battery holders & wire with 2pin jst connector
(07-01-2016, 04:17 PM)dkryder Wrote: adafruit has several battery holders & wire with 2pin jst connector
Could I also just tape the leads of a JST-PH 2pin connector to a 2032 coin cell and call it a day? Looks like that's what all the RTC batteries for laptops look like on Amazon...
regards,
J. Ouellette
    +WiFi/BT +IR
    Android Lollipop
Yup. You could also do a macgyver, pull the white surround off of the two pin RTC socket, and precariously wedge a CR2032 battery in between the two pins! Big Grin Big Grin  The moral of the story is you just need to connect a 3v-ish power source to the RTC pins if you want that functionality!
Well, I didn't MacGyver it, but I did install the adafruit pieces with a couple of spade terminals and electrical tape. Seems to be working....
SaveSave
regards,
J. Ouellette
    +WiFi/BT +IR
    Android Lollipop
Rainbow Lithium battery temperature readout? GregH 0 3,240 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 107,794 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 6,742 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 9,095 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 47,019 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 6,210 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 87,516 09-25-2016, 07:54 PM
  Battery Datasheet xalius 0 3,851 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 3,760 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 29,308 02-18-2016, 05:17 AM
Last Post: German
