recommended micro sd card ?
#81
Thanks.
Very helpful again.
At first I thought that the constraint might be the Pine's 2.0 USB controller but if the random write performance from pine sd card to usb stick went down while the random read performance from Pine sd card to USB stick went up it doesn't seem that the Pine's 2.0 USB controller is what is limiting usb random write performance..
#82
Using an Intergral 64GB USB 3.0:
Run began: Fri Jul 1 21:01:52 2016
Include fsync in write timing
O_DIRECT feature enabled
Auto Mode
File size set to 102400 kB
Record Size 4 kB
Record Size 16 kB
Record Size 512 kB
Record Size 1024 kB
Record Size 16384 kB
Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
Output is in kBytes/sec
Time Resolution = 0.000001 seconds.
Processor cache size set to 1024 kBytes.
Processor cache line size set to 32 bytes.
File stride size set to 17 * record size.
random random bkwd record stride
kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread
102400 4 1816 1668 5914 4980 5395 929
102400 16 5987 6767 18200 17952 17514 3320
102400 512 16531 17967 32526 33244 32805 12625
102400 1024 14803 19849 35492 36330 36312 14429
102400 16384 13931 11563 37908 37925 37153 14658
iozone test complete.
#83
Thanks JamesRead90.
More data is always better!
So for random writes it looks like your Intergral 64GB USB 3.0 is faster (14,658 kBytes/sec) than the Pine64 SD card (11,300 kBytes/sec).
#84
Xalius, how do these results stack up against the Pine64 card and my Integral 64GB USB 3.0? For this test I used my Kingston Datatraveler Ultimate USB 3.0.
Run began: Thu Jul  7 00:48:48 2016
Auto Mode
Record Size 4 kB
Record Size 16 kB
Record Size 512 kB
Record Size 1024 kB
         102400       4     5965     6589    10653    10657     7472      349
         102400      16    12626    12643    21321    21292    21200     1274
         102400     512    16669    13970    38586    38322    38251      807
         102400    1024    12490    12473    39157    39186    39121     1589
         102400   16384    26150    29875    41209    41221    41218    19738
#85
So for random writes and ranked in order of speed from fastest to slowest:
1) Samsung EVO 64 GB xalius 21,690 kB/sec
2) Integral 64GB USB 3.0 Jamesread90 (2nd test) 19,738 kBytes/sec (Kingston Data traveler Ultimate USB 3.0)
3) Sony USB 64 GB USB 3.0 xalius 12,157 kB/sec
4) Integral 64GB USB 3.0 Jamesread90 14,658 kB/sec
5) Pine64 SD card xalius (11,373 kBytes/sec).
This ignores cost of each option.
Jamesread 90 what is the difference between your results in #2 and #4?
#86
Testing Linux pine64 4.7.0-rc1firebuild-MMC #1 SMP PREEMPT Sun Jul 24 11:56:29 CDT 2016 aarch64 GNU/Linux
debian@pine64:~$ iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
        Iozone: Performance Test of File I/O
                Version $Revision: 3.429 $
                Compiled for 64 bit mode.
                Build: linux
        Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins
                     Al Slater, Scott Rhine, Mike Wisner, Ken Goss
                     Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,
                     Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,
                     Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,
                     Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,
                     Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,
                     Vangel Bojaxhi, Ben England, Vikentsi Lapa.
        Run began: Sun Jul 24 17:19:09 2016
        Auto Mode
        Record Size 4 kB
        Record Size 16 kB
        Record Size 512 kB
        Record Size 1024 kB
          102400       4     1610     2793     5949     5955     5940     2852
          102400      16     7435     7585     9155     9176     9175     7645
          102400     512    11091    11199    11644    11624    11633    11122
          102400    1024    11205    11258    11668    11651    11664    11264
          102400   16384    11045    11297    11684    11681    11685    11304
For comparison with the latest BSP 3.10.x kernel (102-2):
ubuntu@pine64:~$ iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
               Build: linux
       Run began: Sat Jun 18 11:29:59 2016
       Auto Mode
       Record Size 4 kB
       Record Size 16 kB
       Record Size 512 kB
       Record Size 1024 kB
         102400       4     2319     3321     7347     7363     7357     3526
         102400      16    10166    12550    14464    14432    14471    12570
         102400     512    21591    21566    23143    23140    23139    21616
         102400    1024    21653    21565    23097    23100    23098    21645
         102400   16384    21678    21662    23084    23082    23082    21690
#87
New data from Pinebook eMMC for comparison, running with performance governor on Linux pinebook 3.10.105-bsp-1.2-ayufan-65 #1 SMP PREEMPT Mon Jun 5 06:57:47 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
    Run began: Sat Jun 17 19:12:37 2017
    Auto Mode
    Record Size 4 kB
    Record Size 16 kB
    Record Size 512 kB
    Record Size 1024 kB
                                                             random    random
         102400       4     4078     4211    19836    19561    13048     3360
         102400      16    18230    18891    50913    51223    37699    14025
         102400     512    55205    54522    84858    84813    83709    49719
         102400    1024    55929    55135    84625    85749    85235    51696
         102400   16384    56507    56041    85515    85579    85930    55151
#88
pine64@pinebook:~$ iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
Build: linux
Run began: Wed Jun 21 23:09:02 2017
Auto Mode
Record Size 4 kB
Record Size 16 kB
Record Size 512 kB
Record Size 1024 kB
          102400       4     3018     3096     8644     8631     8167     3715
          102400      16     8248     8363    16757    16863    16571     9702
          102400     512    21553    21338    23032    22853    22827    20587
          102400    1024    21358    21313    22921    23142    22855    21118
          102400   16384    21168    21375    22947    22915    23134    21070
Forgot to mention that this is one of the new Sandisk A1 32 gig card.
#89
Sandisk Extreme Pro 32GB with A1 / V30 rating
pine64@pinebook:/media/pine64/6532-6630$ iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
        Build: linux
    Run began: Fri Jun 23 18:28:17 2017
    Auto Mode
    Record Size 4 kB
    Record Size 16 kB
    Record Size 512 kB
    Record Size 1024 kB
                                                             random    random
         102400       4     3420     3442     7736     8133     7404     4750
         102400      16     7509     8154    15160    15040    14810    10800
         102400     512    17752    21726    22651    22747    22798    20674
         102400    1024    17836    21356    22843    22907    22877    20994
         102400  16384l    18359    22042    23038    23038    23093    21774
#90
(01-24-2016, 06:10 PM)mronhb Wrote: please excuse the noob question but can anyone please recommend a good brand and class of micro sd card to buy to use with the PINE A64+ w/ 2GB SDRAM. I am very excited about receiving mine in March but very much wanting advice on the best micro sd card to buy. Any advice greatfully accepted thanks  Smile
Hello
The choice of sdcard is rather important, sd cards suffer from a symptom called 'Wear Level', this where cards that are constantly being written over and over again such as dashcams or video camera cards, suffer premature failure due to data blocks within the memory stack being corrupted and not accepting any more data. The blocks are tagged in the VTOC (Volume Table of Contents) and the 32gb sdcard is no longer 32gb, The Samsung line of SDcards (extreme usage) though a little more expensive seem to hold up the best when benchmarked, it is very important that the card is specified for high read/write (sometimes you may see a card specified for video for example) and the phrase the phrase Extreme Usage' should be displayed in the item description, this information is well known to the SD card manufacturers and is just now making its way into general parlance.
  Recommended kits to buy? Silk 1 5,826 12-06-2020, 11:28 PM
  How to boot from SD card on pinebook pro linux123 3 10,420 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 7,161 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,238 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 10,377 03-18-2020, 09:42 AM
  eMMC card on adapter Malmgren 8 19,016 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 16,225 02-08-2017, 05:42 PM
Last Post: maxpayne
  unable to write an pine64 image on a 16G micro suresh 2 8,695 01-26-2017, 12:56 PM
Last Post: suresh
  recommended micro sd card? Gustavo Woltmann 1 6,177 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 6,158 11-03-2016, 02:33 PM
