Papercraft Enclosure
This is my low cost enclosure, I did it using kraft paper(cardboard) and a cutting machine(silhouette cameo), although you could print it and cut the lines manually.
This is a work in progress and if anyone would like to try I could share the files here.
Can you send us the file ? I would love to do it Big Grin
Very very impressive. That said, I spent half a day cutting out stencils for a project (pigrrl) today - didnt get a single one right, so I think I stay clear Wink I envy your skills ...
Very interesting. Any chance to share daa how to make this enclosure ?
Thanks guys, this weekend I will spend more time working on improving it and I will share the results, pepakura file,.pdf and a STL with you.
the 3d model is just a box, simple as that
As this is a paper box, I'm out of ideas to fix the board
any ideas?
I took a pic today to show another problem, I glued every thing, even the top lid Smile, then I have to open the box and now I need another idea to create a kind of  lid, maybe with magnetic, I dunno.
maybe use velcro dots.
(06-29-2016, 01:12 PM)tiagomr Wrote: Thanks guys, this weekend I will spend more time working on improving it and I will share the results, pepakura file,.pdf and a STL with you.
any ideas?
Thanks. When you finish, please share with us.
Sorry guys for the late response,
in the zip file there are a PDF/OBJ/PDO folders
PDF has some models already in pdf to print and cut manually
OBJ is the simple 3d object
PDO is the files from pepakura design where you can change the cutting settings for your model
Currently I'm exporting from pepakura to silhouette studio and cutting in the machine(if you want the silhouette files I can attach here)
the model I'm using is the one in PDF\fullpine12x12.studio3.pdf as the machine uses a 12inx12in paper
any suggestion please advice
I'm still wondering if it worth having an top lid that I can open sometimes, I'm using it as a TV box only so I don't see any reason to open the top lid, then I glued all the flaps.
.zip   papercraftCase.zip (Size: 955.9 KB / Downloads: 697)
(07-18-2016, 03:17 PM)tiagomr Wrote: Sorry guys for the late response,
Tnx for the  papercraftCase file
(07-18-2016, 03:17 PM)Thank you! tiagomr Wrote: Sorry guys for the late response,
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 29,857 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 47,960 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 9,287 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 11,541 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 8,851 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 19,350 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 35,088 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 28,954 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 26,521 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 9,655 10-13-2016, 08:47 AM
Last Post: Bluphire
