VESA mount enclosure
I was wondering if the PINE team (or even a third party) was planning on making an enclosure compatible with VESA for mounting the PINE 64 to the back of a monitor?
I have a similar enclosure for Raspberry Pi, and it is very handy for having a nice low profile low power computer for internet browsing, watching, movies, etc. Similar to this: https://www.adafruit.com/products/2534
(01-27-2016, 03:58 PM)john Wrote: I was wondering if the PINE team (or even a third party) was planning on making an enclosure compatible with VESA for mounting the PINE 64 to the back of a monitor?
I believe there was some mention of a VESA mount in one of the kickstarter updates, I'll try to track it down...
...yes! Here it is, update #11:
https://www.kickstarter.com/projects/pin...ts/1449625
- John Yendt on December 22 -
"Just another thought, perhaps a case that can VESA mount to the back of a monitor."
- PINE64 Inc. on December 23 -
"@john yendt, we're working with another company to develop a VESA mount already."
Thanks for looking for that and linking it! For the record, I'm not the same John as Mr. Yendt.
We have plan to do the Vesa mount but only available on March or April timeframe.
tlliim: are there going to be standard dimensions available soon? I would like to be able to start designing my own case but have had trouble finding any real specifications on mounting hole locations and other critical dimensions.
If you just need the outter dimension and hole position, the Rev A and rev B are the same.
(02-01-2016, 11:30 PM)tllim Wrote: tlliim: are there going to be standard dimensions available soon? I would like to be able to start designing my own case but have had trouble finding any real specifications on mounting hole locations and other critical dimensions.
Try this link: http://wiki.pine64.org/images/7/74/Pine6...ension.JPG
If I've helped you with something, please leave a rating for my responses.
Sounds promising! Otherwise I will be getting a VESA adapter plate and mount a standard case onto it Smile.
Hi !
I also make some open enclosure models.. (Still in development)
The bottom is somewhat larger than the top. In order to adapt the VESA holes.  (100mm x 100mm) and (75mm x75mm)
I used 4 hexagons nylon spacers 25 mm long
At the top will be the button battery holder for RTC and I am waiting to receive the mini fans to cooling.
Bye!!
Here is a mount that we make - available on Amazon that works with any 100mm monitor.
http://www.amazon.com/ASG-Laser-VESA-Mou...B01DG5ITSU
or with a clear top to show off the Pine 64
http://www.amazon.com/VESA-Mount-Pine-64...B01DG5OZDI
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,683 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 51,503 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,526 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 12,910 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,919 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,170 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 39,143 01-06-2017, 03:15 AM
Last Post: Learnincurve
  VESA 100 Arm mounts rickseiden 11 29,378 12-31-2016, 11:01 AM
Last Post: androsch
  Tablet Enclosure Vachtra 11 31,606 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 28,630 11-01-2016, 06:23 PM
