I started blogging on Pine64 Cluster
See http://singleboard.org Feedback and suggestions appreciated
(06-25-2016, 07:52 PM)salmangano Wrote: See http://singleboard.org Feedback and suggestions appreciated
Nice blog and interesting. I like your writing style.
I know some people made their own power supplies to power the board directly on some pins instead of the USB. However your solution looks nice.
I do not know much about cluster computing (accept as a user) so I will be interested to read about your adventures
here's mine
[Image: hardatwork.jpg]
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
Nice blog.
After the dust settles, I think I'm going to make a cluster. :-). I have two pines already.
hey salmangano just so you know all you had to do in order to change mac addresses was to change the entry in the /boot/uEnv.txt and if you take notice under the board it does display the actual mac address for that particular board.
Once you are done with you tutorial feel free to post it at https://www.pine64.pro Wink
Cheers Big Grin
What are you going to do with cluster? Smile
Thanks on the good article.
@Lenny,  NICE !
... what's with the single board outside the cluster tower?  Which Lego set did you use... ad hoc blocks ? Really, very cool design (actually, that's the best I've seen so far)...
Good post, but I recommend manually resizing the pictures you've included in it. Takes a long time to load your page on a slow network since those pics are almost 10mb each in size.
Some with certainty insist no certainty exists.
  Cluster Software Madroxprime 1 8,550 04-03-2017, 06:57 AM
Last Post: Shad0wSt4R
  Cluster / Render Farm Ron Piggott 15 40,045 10-02-2016, 02:55 PM
  Bargain 5 Node Cluster of PINE A64+ from Climber.net tllim 8 22,698 10-02-2016, 07:01 AM
Last Post: sheffield_nick
  Batch Schedulers on pine64 cdslashetc 0 5,154 07-24-2016, 09:19 AM
Last Post: cdslashetc
  Pine64 Cluster economy baryluk 5 17,232 06-19-2016, 09:13 AM
Last Post: JasperBrown
  cluster computing jproffer 20 56,840 05-05-2016, 04:13 PM
Last Post: pineresearch
  Cluster capable? W1SPY 7 19,620 02-25-2016, 10:34 PM
Last Post: hrh1818
