php7 for debian?
I am running the may 8 xfce build and I can't seem to find a repo that has php7 available.  I'm fairly new to Linux so I may just be looking in the wrong places.  If php5 is all that's available that's fine, I just want to make sure before I install it.
(06-20-2016, 12:35 PM)baldrob Wrote: I am running the may 8 xfce build and I can't seem to find a repo that has php7 available.  I'm fairly new to Linux so I may just be looking in the wrong places.  If php5 is all that's available that's fine, I just want to make sure before I install it.
no, php7 works just fine.
Okay, so what repo do I have to add to get it?  Right now when I do a sudo apt-get install for php7.0-cgi or php7.0-fpm I get "unable to locate package 'php-7.0-cgi' ".
you could try a sudo apt-get update
sudo apt-get upgrade
this will help you rebuild the build data cache from the repositories
maybe help you find a broken repo address.
here you go from the guys at howtoforge Wink
https://www.howtoforge.com/tutorial/how-...on-debian/
skip anything related to ISPConfig Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
(06-20-2016, 08:04 PM)lenny.raposo-pine64.pro Wrote: here you go from the guys at howtoforge Wink
Thanks for this, looks like what I was looking for.
  Debian installer on Pine A64+ but no hdmi mrwick 1 9,048 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,442 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,502 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 16,802 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 165,611 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,389 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,739 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 10,999 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 21,095 03-29-2019, 02:00 AM
Last Post: desai_amogh
  (ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 259 671,853 05-21-2018, 06:30 AM
Last Post: Luke
