Wifi no longer works
Hello everyone,
I've been running Arch Linux ARM on my Pinebook Pro, and the Wi-Fi was working perfectly until some recent kernel updates. From what I've gathered, there are different Pinebook Pro revisions with slightly different Wi-Fi chips, which may be contributing to the problem.
I've tried several suggested fixes, including manually copying files from /lib/firmware/brcm and experimenting with various PKGBUILDs I found through online searches, but nothing has worked so far.
I'm still unable to get the Wi-Fi working. Has anyone experienced the same issue and found a reliable solution? Any suggestions or guidance would be greatly appreciated.
Thanks in advance!
That sounds like the firmware package changing under you after a kernel update. I had a similar thing on a different ARM laptop a couple of years ago, Wi-Fi just vanished after an update one evening, and it turned out the firmware files had moved. Before you chase more PKGBUILDs, can you check which kernel version you are on now, and whether the old one still boots with Wi-Fi? That would narrow it down a lot.
NorrisFByrd's kernel test is the quickest split. If the old kernel works, compare `dmesg | grep -i brcmfmac` on both: it usually prints the exact firmware filename it requests before failing. That tells you whether the new kernel expects a different brcmfmac file or a missing symlink, rather than guessing with PKGBUILDs. Also check `rfkill list` and `ip link` to confirm the interface isn't just soft-blocked. If dmesg shows no brcmfmac lines at all, it's more likely a module/kernel config regression than firmware.
Wordle 1,981 3/6
AUDIO ⬜⬜⬜⬜⬜
STARE ??⬜⬜?
STENT ?????
Slow start with AUDIO, then STARE did the work. I was still half asleep and nearly typed the wrong third word.
  Ubuntu 25.04 beta works, kinda RMJ250 3 6,138 04-14-2025, 09:01 PM
Last Post: RMJ250
  Problem with Wifi, Sleep, Video and PGP signature Anarethos 4 7,135 03-31-2025, 07:14 AM
Last Post: Anarethos
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 3,162 07-13-2023, 01:50 PM
Last Post: PaulQ
  Finally... The touchpad works great! dsimic 111 238,745 03-13-2023, 09:41 PM
Last Post: kellrobinson
  wifi missing some networks filip 0 2,331 03-11-2023, 03:21 PM
Last Post: filip
  PBP green LED works but blank display. frerebo 1 3,847 02-22-2023, 03:11 AM
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 6,997 10-08-2022, 06:22 PM
  WiFi Signal Strength? B34N 1 3,398 07-22-2022, 01:35 PM
Last Post: poVoq
  wifi hotspot ip address symbol.accounting@gmail.com 1 4,427 11-07-2021, 12:58 AM
Last Post: dukla2000
  Wifi Troubles IDEFK 17 29,198 05-24-2021, 05:03 AM
Last Post: walterbe
