Why projects like PinePhone matter – feedback and encouragement
The PinePhone was not discontinued, only the PinePhone Pro was.
(09-15-2025, 12:41 PM)zetabeta Wrote:
(09-15-2025, 01:44 AM)Gary2003 Wrote: I started researching seriously. I thought that sooner or later, I would probably have to switch to the iPhone, which today seems more respectful of privacy than Android smartphones.
apple and privacy .... may i laugh for 2 days!
maybe apple doesn't leak data to third parties like ads, but data is used in-doors. apple collects data like others.
and personally i think android might be better than ios in case of privacy, although it is complicated. maybe average stock android without modifications is worse than ios. but android could be debloated, although difficult. installing custom image is better way to go, although only on some devices.
where apple is definitely worse than alphabet inc and android manufactures, is lack of user control. apple controls roughly everything in their devices from bootloader to apps. in the longer run, if user doesn't have control over their devices, can they have privacy either. privacy might be just apple's empty promise and totally up to apple to keep it.
Indeed, it is important to point out all these issues regarding Apple.
Yes, in my research, I saw that there are modified versions of Android, but I had some questions about their reliability.
(09-15-2025, 02:12 PM)Kevin Kofler Wrote: The PinePhone was not discontinued, only the PinePhone Pro was.
Thank you, it’s good to clarify that.
Gary2003  Smile
Only Pinephones (and maybe Librem) are confirmed incompatible with Cellbright if the boot flash is encrypted.
Apple and Android are born compromised, for the same reasons you can jailbreak or root locked bootloader phones, so can anyone else.
https://cellebrite.com/en/home/
https://en.wikipedia.org/wiki/Cellebrite
https://en.wikipedia.org/wiki/Cellebrite_UFED
The UFED (Universal Forensics Extraction Device) is a product series of the Israeli company Cellebrite, which is used for the extraction and analysis of data from mobile devices by law enforcement agencies.[1]
Features
On the UFED Touch, it is possible to select extraction of data and choose from a wide list of vendors. After the data extraction is done, it is possible to analyze the data in the Physical Analyzer application.[14]
The Cellebrite UFED Physical Analyzer supports the following features:[14]
  • Extract device keys which can be used to decrypt raw disk images, as well as keychain items.
  • Revealing device passwords, although this is not available for all locked devices
  • Passcode recovery attacks
  • Analysis and decoding of application data
  • Generating reports in various formats such as PDF and HTML
  • Dump the raw filesystem for analyzing it in other applications
(09-16-2025, 03:03 AM)biketool Wrote: Only Pinephones (and maybe Librem) are confirmed incompatible with Cellbright if the boot flash is encrypted.
Features
What's the plan? Are we throwing away all our iPhones and Samsungs, and is everyone getting a PinePhone? That’s the safest bet for our mission...
[Image: fast_five_12.jpg]
Mia on the Pine64 website, placing an order for the whole crew...
Gary2003  Smile
  PinePhone Game Thread PixelPaintbrush 31 79,866 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 22,051 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 6,875 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,088 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 942 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,168 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,711 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,323 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 6,723 10-21-2025, 12:12 PM
Last Post: Richy_T
  Does PinePhone support long-term battery health optimization? roseblack 5 3,115 10-06-2025, 09:05 PM
